Aeotec Nano Device Automatically removed after inclusion
    I have experienced an unusual issue with including an Aeotec Nano ZW-111-B AU that every time it is included, it is automatically removed. I have attempted this a number of time and the outcome is exactly the same. Z-wave 3.0.1.150
    Oct-22 16:35:24	 	Z-Wave	DEVICE RESET LOCALLY: Node removal process completed. (Node 124)
    Oct-22 16:35:23	 	Z-Wave	7 out of 8 Child devices of node 124 were created successfully.
    Oct-22 16:35:23	 	Z-Wave	Setting a polling interval of 21 Minutes, 56 Seconds on device Switch Multilevel
    Oct-22 16:35:23	 	Z-Wave	Setting a polling interval of 20 Minutes, 54 Seconds on device Switch Binary
    Oct-22 16:35:22	 	Z-Wave	Setting a polling interval of 20 Minutes, 52 Seconds on device Notification
    Oct-22 16:35:22	 	Z-Wave	Setting a polling interval of 20 Minutes, 50 Seconds on device Amperes
    Oct-22 16:35:21	 	Z-Wave	Setting a polling interval of 20 Minutes, 48 Seconds on device Volts
    Oct-22 16:35:21	 	Z-Wave	Setting a polling interval of 20 Minutes, 46 Seconds on device Watts
    Oct-22 16:35:21	 	Z-Wave	Adding Watts as an Energy tracking device.
    Oct-22 16:35:21	 	Z-Wave	DEVICE RESET LOCALLY: Node removal process completed. (Node 124)
    Oct-22 16:35:21	 	Z-Wave	Node 124 was removed successfully.
    Oct-22 16:35:20	 	Z-Wave	Adding Node 124 Z-Wave kW Hours as an Energy tracking device.
    Oct-22 16:35:20	 	Z-Wave	Home: Controller firmware version: 1.0
    Oct-22 16:35:20	 	Z-Wave	Home: Controller Manufacturer: Aeon Labs, ID=0x5A, Type=0x3
    Oct-22 16:35:15	 	Z-Wave	Getting association information for Node 124 Z-Wave Aeon Labs Switch Multilevel
    Oct-22 16:35:15	 	Z-Wave Warning	Failed to set the current date and day of the week using the CLOCK command class on Node 124 Z-Wave Aeon Labs Switch Multilevel
    Oct-22 16:35:15	 	Z-Wave Warning	Error setting CLOCK for node 124, Send failed.
    Oct-22 16:35:02	 	Z-Wave	Successfully removed node 124 from interface Home.
    Oct-22 16:35:02	 	Z-Wave	Home: Node 124 was removed from interface Home.
    Oct-22 16:34:41	 	Z-Wave	Root Node Device Node 124 Z-Wave Aeon Labs Switch Multilevel was created for node 124 on network F6EDF82A
    Oct-22 16:34:29	 	Z-Wave Warning	Could not get the SWITCH command class version for node 124 .
    Oct-22 16:33:40	 	Z-Wave	Removing node 124 from interface Home
    Oct-22 16:33:37	 	Z-Wave Warning	Device Reset Locally Notification received for node 124 - NODE IS BEING REMOVED FROM THE SYSTEM.
    Oct-22 16:33:37	 	Z-Wave	Node 124 Meter is Supported for Electric_meter, Type ELECTRIC_A, Scale is INSTANT
    Oct-22 16:33:37	 	Z-Wave	Node 124 Meter is Supported for Electric_meter, Type ELECTRIC_V, Scale is INSTANT
    Oct-22 16:33:37	 	Z-Wave	Node 124 Meter is Supported for Electric_meter, Type ELECTRIC_W, Scale is INSTANT
    Oct-22 16:33:37	 	Z-Wave	Node 124 Meter is Supported for Electric_meter, Type ELECTRIC_kWh, Scale is ACCUMULATED
    Oct-22 16:33:36	 	Z-Wave	Node 124 is a Z-Wave Plus node. Retrieving ZWPlus Info...
    Oct-22 16:33:36	 	Z-Wave	Node 124 is Z-Wave version: Lib: 4.38 App: 1.2
    Oct-22 16:33:35	 	Z-Wave	Node: 124 Controls Class(es): HAIL
    Oct-22 16:33:35	 	Z-Wave	Node: 124 Supports Class(es): ZWAVEPLUS_INFO, VERSION_V2, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, POWERLEVEL, ASSOCIATION_V2, ASSOCIATION_GRP_INFO_V2, SWITCH_BINARY, SWITCH_MULTILEVEL_V3, SWITCH_ALL, METER_V3, CONFIGURATION_V4, CLOCK, NOTIFICATION_V6, SCENE_ACTUATOR_CONF, SCENE_ACTIVATION, FIRMWARE_UPDATE_MD_V2
    Oct-22 16:33:35	 	Z-Wave	Z-Wave manufacturer information for node 124, ID: 134=86H (Aeon Labs), Type: 515=203H, ID: 111=6FH
    Oct-22 16:33:35	 	Z-Wave	Checking if we can reach node 124
    Oct-22 16:33:35	 	Z-Wave	Getting class information for node 124...
    Oct-22 16:33:35	 	Z-Wave	Device synchronization needs to get Z-Wave class information for one node.
    Oct-22 16:33:35	 	Z-Wave	Synchronize nodes finished. Number of device nodes to be created/added = 1
    Oct-22 16:33:34	 	Z-Wave	Done. Node 124 Added
    HomeSeer Version: HS3 Pro Edition 3.0.0.368 (Windows)
    HomeSeer: Is Registered
    OS Version: 10.0.15063 Service Pack: 0.0
    System Uptime: 0 Days 3 Hours 9 Minutes 46 Seconds
    Network Adapter: Adapter -> Intel(R) 82579V Gigabit Network Connection IP:
    Network Adapter: HomeSeer Adapter -> Loopback Address (localhost) IP: 127.0.0.1
    Web Server Port/SSL Port: 80 / 443
    Number of Devices: 837
    Number of Events: 83
    Number of unique event scripts used: 1
    Plug-Ins Enabled: Z-Wave:,Sonos:,RFXCOM:,ImperiHome:,HSBuddy:,EnvisaLink:,DoorBi rd:,EasyTrigger:
    Processor Type and Speed: Intel64 Family 6 Model 42 Stepping 7 at 3.17 GHz
    Modules/Threads: 146 Modules, 115 Threads
    Available Threads: 800
    System Processes/Load: 188 Processes, 6% Load
    Free / Total Physical Memory: 4.62 GBytes / 7.98 GBytes (58% free)
    Free / Total Virtual Memory: 5.08 GBytes / 9.23 GBytes (55% free)
    HomeSeer Memory Used: 127 Mbytes
    Plug-In Memory Used: 8 EXE Plug-Ins using 318 Mbytes
    Finally got it to stay enrolled, well temporarily and it was working. Then after using the switch, it once again automatically removed device.
    Oct-22 17:31:32 Z-Wave Removing node 125 from interface Home
    Oct-22 17:31:30 Device Control Device: Lights Bedroom 1 Master Bedroom Dimmer to On (99) by/from: CAPI Control Handler
    Oct-22 17:31:29 Z-Wave Warning Device Reset Locally Notification received for device Node 125 Z-Wave Aeon Labs Switch Multilevel - DEVICE IS BEING REMOVED FROM THE SYSTEM.
    Oct-22 17:31:22 Z-Wave Device: Node 125 Z-Wave Switch Multilevel Set to 0
    Oct-22 17:31:22 Device Control Device: Lights Bedroom 1 Master Bedroom Light to Off (0) by/from: CAPI Control Handler
      Below is the 4th attempt and it produced the same results
      Oct-22 17:38:29 Z-Wave Device: Lights Toilet Downstairs Volts 3 Set to 235.5 (235.5 Volts)
      Oct-22 17:38:27 Z-Wave 8 out of 9 Child devices of node 126 were created successfully.
      Oct-22 17:38:27 Z-Wave Setting a polling interval of 23 Minutes, 0 Seconds on device Switch Multilevel
      Oct-22 17:38:26 Z-Wave Setting a polling interval of 22 Minutes, 58 Seconds on device Switch Binary
      Oct-22 17:38:26 Z-Wave Setting a polling interval of 22 Minutes, 56 Seconds on device Power Management Notification
      Oct-22 17:38:25 Z-Wave Setting a polling interval of 22 Minutes, 48 Seconds on device Heat Notification
      Oct-22 17:38:25 Z-Wave Setting a polling interval of 22 Minutes, 46 Seconds on device Amperes
      Oct-22 17:38:25 Z-Wave DEVICE RESET LOCALLY: Node removal process completed. (Node 126)
      Oct-22 17:38:25 Z-Wave Node 126 was removed successfully.
      Oct-22 17:38:25 Z-Wave Setting a polling interval of 22 Minutes, 44 Seconds on device Volts
      Oct-22 17:38:24 Z-Wave Setting a polling interval of 22 Minutes, 42 Seconds on device Node 126 Z-Wave Watts
      Oct-22 17:38:24 Z-Wave Adding Node 126 Z-Wave Watts as an Energy tracking device.
      Oct-22 17:38:24 Z-Wave Setting a polling interval of 22 Minutes, 12 Seconds on device Node 126 Z-Wave kW Hours
      Oct-22 17:38:24 Z-Wave Adding Node 126 Z-Wave kW Hours as an Energy tracking device.
      Oct-22 17:38:24 Z-Wave Home: Controller firmware version: 1.0
      Oct-22 17:38:24 Z-Wave Home: Controller Manufacturer: Aeon Labs, ID=0x5A, Type=0x3
      Oct-22 17:38:24 Z-Wave Warning Failed to set the current date and day of the week using the CLOCK command class on Z-Wave Aeon Labs Switch Multilevel
      Oct-22 17:38:24 Z-Wave Warning Error setting CLOCK for node 126, Send failed.
      Oct-22 17:38:20 Z-Wave Successfully removed node 126 from interface Home.
      Oct-22 17:38:19 Z-Wave Home: Node 126 was removed from interface Home.
      Oct-22 17:38:00 Z-Wave Root Node Device Z-Wave Aeon Labs Switch Multilevel was created for node 126 on network F6EDF82A
      Oct-22 17:38:00 Z-Wave All associations for node 126 have been retrieved successfully.
        Old thread, I know (sorry).
        It's just that this was the only hit on my search as I currently have a similar issue.
        I have followed (almost) every tips and tricks out there to solve this. I say almost because there is probably more
        My case is that I had a floodlight sensor (Steinel) connected to HomeSeer and that worked fine in the beginning. Then I experienced issues, no connection etc. Figured it was probably because of signal loss to outside of my house.
        Then suddenly HomeSeer (or Zwave?) uninstalled this device without any action from me. This was in the log:
        "Device Reset Locally Notification received for device xxx xxx Switch Binary - DEVICE IS BEING REMOVED FROM THE SYSTEM"
        And afterwards the HS log was filled with these:
        "DEVICE RESET LOCALLY: Node removal process completed (Node 32)"
        "Node 32 does not exist in interface UZB"
        Since HS had uninstalled Node 32 I could not find it anywhere. Not in the device list, not in the node list, not even in the Zwave backup file. So I could not figure out how to remove it properly. I also tried closing HS and unplugging my UZB stick (Zwave) - no luck.
        Writing this post I tried the same again - closing HS, unplugging UZB, but this time I kept it unplugged for about 5 minutes. And guess what - actually seems like it worked! I will check back here if it does not solve itself.
        Anyway, why bother writing all this? I guess I hope that somebody might need this info later on :-)
