Thank you! I'll definitely install tomorrow.
Rain Today looks like it is an integer?
Originally posted by CFGuy View PostI just posted version .31 to the updater. This changes the Rain totals to 2 decimal places. Some providers may not provide rain totals.
and pulled back into HS3. the only problem is I'm seeing .2" instead of .02".
[EDIT]
I ran a TTS event to read out the last hour and day's rainfall. For the day it said "zero point zero two inches", so the TTS is correct for the rainfall today, but the TTS WXML Speak Item for Last Hour read out 0.15".
While trying to figure this all out and editing this post, I went back to look at the HS3 wXML devices and both are again at 0 both on the device screen, and when I drill down into the Advanced screen on the device. Oddly, the event I wrote now says "No rain in the past hour" (could be because it was before the start of this hour when I induced the reading), and the day's rainfall still says "zero point zero two".
I have some errands to run this afternoon so I won't be able to look at it until this evening.
In the HomeSeer HS3/Data/weatherXML folder look for a file called WUCondition1.xml. Grab that file so it doesn't get overwritten.
Look in the file, or email it to me and I'll check, to see what the values are for the rain totals.
Look for the key precip_today_in and precip_1hr_in. Those values are what weatherXML is reading.
However, since you have your own weather station, it might be better to look into a way to just grab your values rather than going through weather underground first.
Jeff Farmer
HS 3, HSPhone
I grabbed the file, and here is what's in it:
<precip_1hr_string>0.00 in ( 0 mm)</precip_1hr_string>
<precip_1hr_in>0.00</precip_1hr_in>
<precip_1hr_metric> 0</precip_1hr_metric>
<precip_today_string>0.02 in (1 mm)</precip_today_string>
<precip_today_in>0.02</precip_today_in>
<precip_today_metric>1</precip_today_metric>
Edit: I figured that wasn't going to help with regard to the hourly total, so I went out and put another 2 clicks (.02) of water into the rain gauge and now I have this in the WUCondition1.xml file (file attached):
<precip_1hr_string>0.19 in ( 5 mm)</precip_1hr_string>
<precip_1hr_in>0.19</precip_1hr_in>
<precip_1hr_metric> 5</precip_1hr_metric>
<precip_today_string>0.04 in (1 mm)</precip_today_string>
<precip_today_in>0.04</precip_today_in>
Note that the hourly is either coming in incorrectly from WU, or is being written into this XML file incorrectly. It says 0.19 in ( 5 mm). While both of those figures are the right conversion to each other, the actual rain value in the past hour is .02" (.508mm) and the new daily total is .04" which would be 1.016mm.
Weather TTS just read this:
The xml file is downloaded direct from Weather Underground, so what you see in the xml file is what WU is sending.
I've made a couple of changes and will try to get some time today to upload the new version. Have some errands and then a birthday party for my 2 year old grandson today so most likely will be tomorrow.--
Jeff Farmer
HS 3, HSPhone
Originally posted by CFGuy View PostThe xml file is downloaded direct from Weather Underground, so what you see in the xml file is what WU is sending.
Did this ever get resolved? I still see an integer for the "Rain Today" device and a floating point value for wxmlRainT_1.
For example right now I see
wxmlRainT_1 = 0.01
and
Rain Today = 0
Would be great to have this sorted so I can use the device in a rule to disable sprinklers.
Geoff
Originally posted by geoffb View PostDid this ever get resolved? I still see an integer for the "Rain Today" device and a floating point value for wxmlRainT_1.
wxmlRainT_1 = 0.01
and
Rain Today = 0
Geoff--
Jeff Farmer
HS 3, HSPhone
Originally posted by CFGuy View PostGo to the weatherXML Units page. At the bottom there are dropdowns to control how many decimal places you want for the different units.
"Round rain totals to" was already set to a value of "1 decimal place". The current wxmlRainT_1 shows 0.06 but I was getting "0" as a value in the device.
Changing the drop-down to a value "2 decimal places" then changes the device to give me a value of 0.1.
Changing the drop-down to a value "3 decimal places" still leaves the device value at 0.1.
I don't think I'm running the beta, though?
Geoff
Originally posted by geoffb View PostToo easy! Thanks! Note that it seems to still have slightly odd behavior:
Geoff--
Jeff Farmer
HS 3, HSPhone
