I'm not a programmer so I don't know if there's a lot of effort involved with this. I do know it's possible since I just moved over to the Vera and the EVL3 plugin on the Vera was able to populate zone names from the panel.
[Suggestion] Pull zone names from EVL3
Originally posted by spud View PostI investigated a little, and it seems like it's possible by entering programming mode and reading zones data.
If there is a lot of demand for this feature, I will give it a shot, but I would need help for testing because I don't have an Ademco panel to test with.
Looks like this was not put in?
I'd like this also - major PITA to rename everything... especially after you uninstall/reinstall the plugin when it is not working... and have to spend another hour renaming everything, again.
At min, please have an INI file where we can quickly copy/paste names into and save the INI for backup/recovery.
Originally posted by spud View Postin version 3.0.0.26 available here you can rename and set the type of each zone from the Config page. Clik the "Update zone devices" button once everything is configured to update your devices.
The names and types are then store in the EnvisaLinkAdemco.ini file.
[ATTACH]62263[/ATTACH]
[ATTACH]62264[/ATTACH]
