I have a Honeywell Vista 20p with the Envisalink 4. Has anyone else been experiencing any TPI Session Closed and TPI Login events? I'm coming from the Envisalink DSC plug-in with the Envisalink 3 and never noticed these events before (I get texted any time the plugin connects and disconnects from the Envisalink).
I'm seeing this fairly regularly throughout the day whether the system is armed or not. When it happens, the plug-in will usually connect right back to the Envisalink within about 5-10 seconds. Here is a snip it of the debug log when the disconnect occurs.
Feb-11 10:35:25 DEBUG Request: DumpZoneTimers ^02,$
Feb-11 10:35:30 ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Feb-11 10:35:30 DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at EnvisaLinkAdemco.Communications.Reciever.Run()
Feb-11 10:35:30 INFO Connection Lost, will try to reconnect in 10 seconds
Feb-11 10:35:41 INFO Trying to reconnect to: envisalink:4025
Feb-11 10:35:41 INFO Reconnection OK
Feb-11 10:35:41 ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
Feb-11 10:35:41 DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
Feb-11 10:35:41 INFO Connection Lost, will try to reconnect in 10 seconds
Feb-11 10:35:52 INFO Trying to reconnect to: envisalink:4025
Feb-11 10:35:52 INFO Reconnection OK
Feb-11 10:35:52 DEBUG Received: Login:
Feb-11 10:35:52 DEBUG Request: SendKeystrokeString xxxxxx
Feb-11 10:35:52 DEBUG LoginInteraction
Feb-11 10:35:52 DEBUG Received: OK
Current Date/Time: 2/11/2018 1:57:45 PM
Operating System: Microsoft Windows 10 Pro - Work Station
System Uptime: 23 Days 1 Hour 43 Minutes 45 Seconds
Number of Devices: 596
Number of Events: 512
Available Threads: 400
Enabled Plug-Ins
3.0.0.43: EasyTrigger
3.0.0.29: EnvisaLinkAdemco
1.1.12.0: Honeywell WiFi Thermostat
3.0.0.6: HSZigBee
3.0.0.28: MediaController
3.0.0.14: NetCAM
2.1.6.0: OpenSprinkler
3.0.1.114: PHLocation
3.1.0.22: Sonos
3.0.6601.28887: UltraLighting3
3.0.0.80: weatherXML
3.0.1.193: Z-Wave
Enabled Plug-Ins
3.0.0.6: HSZigBee
3.0.0.14: NetCAM
3.1.0.22: Sonos
3.0.1.193: Z-Wave
