Warning about Early Binding
    Please see:
    http://msdn.microsoft.com/en-us/libr...6b(VS.71).aspx
    Note: Another way to define a procedure with optional arguments is to use overloading. If you have one optional argument, you can define two overloaded versions of the procedure, one with the argument and one without it.
    tenholde
      Originally posted by tenholde View Post
      I am now truly confused by the response to this issue.
      Method overloading can be used for both differing argument type and count.
      I believe the problem is that they absolutely have to make the two last options for hs.Run optional for some reason.
      And in .NET this can't be done:
      Sub Run(byval scriptname as String)
      End Sub
      Sub Run(byval scriptname as String, Byval optional wait as Boolean = False, byval optional single_instance as Boolean = False)
      End Sub
      But I don't see the problem, as this is perfectly legal:
      End Sub
      Sub Run(byval scriptname as String, Byval wait as Boolean, byval single_instance as Boolean)
      End Sub
      It's not a problem at all in my head. Just force the users of the last overload Run to specify both arguments. This is new anyway, so there should not be any compability issues with that. Problem solved!
        You don't have to use optional parameters at all. You can just define each combination of parameters in multiple overloads. A little extra work for the developer, saves many headaches for the customers.
        tenholde
        tenholde
          Everyone,
          thanks for your responses and inputs. I think we have shed some light on this issue and provided HST with an alternative to optional parameters.
          I hope they will give this a try next time they want to extend an existing method.
          I would think from a documentation standpoint overloads would also be better because hs wouldn't have 2,3,4 methods with different names basically doing the same thing
          Mark
          HS3 Pro 4.2.19.5
            This is why I prefer to program in VHDL or ASM.
            'course, I can see where it might take me a bit longer to do the same thing other people are doing
            I just find it interesting, when I program in VB, I have to write out what I want the "thing" to do, then look up all the function names. I guess I should get tenholde's stuff up and running...but I am a notepad kind of guy... I think the highest level of programming that I really enjoyed was C, when I wrote my own OS. When I get to C++ or anything like VB...for me, my personal opinion, the Objects tend to get in the way. BUT, I have used them and programmed in them...I just don't prefer it!
            --Dan
              #21
              One last question,
              Will the overloads work ok if someone accesses the HS API with C# or C++?
              Both languages support overloads so it would seemm logical that they could call an overloaded method written in vb.net
              Mark
              HS3 Pro 4.2.19.5
                #22
                --Dan
                try it, you'll like it.
                tenholde
                  #23
                  Just reading through this thread, I couldn't agree more with the overloading. I was almost ready to hit replay and say YES you can, you just don't make it optional that way you add a second method with the extra parameters.
                  This also got me thinking about the future.
                  Named parameters are supported in .net 4, so maybe the next version of homeseer could take advantage of optional parameters in a little bit more efficient way. You could have multiple optional parameters if you do it that way, and specify them in any order you want.
                  Joe (zimmer62)
                  BLSecurtiy, AC-RF2, RCS Serial Thermostats, RFXCOM SMarthome SwitchLinc, mcsXap, Global Cache GC100, SqueezeBox, TWA_ONKYOINTEGRA, BLLogMonitor, BLPlugins, BLRadar, BLSpeech, BLZLog.aspx, HSTouch (Windows, iPhone, iPod), USB Mimo touchscreens, VMWare Server, Vortexbox, Windows Home Server, MyMovies, Windows Media Center, X10, ZWave, and much much much more.
                    #24
                    Part of the reason, you have to remember, is that HomeSeer is 10 years old and there is a LOT of legacy code in there. The only way we could do it years ago was to create a separate procedure, and Microsoft's defacto standard for that was to add an "Ex" to the end of the procedure name that it is modeled after. Fast forward many years, and it was only last year that we started to get some serious requests for overloading rather than optional parameters - Mark had requested it but with nobody else asking and not much in the way of new development happening, AND still being on an older version of Visual Studio, we left things as it was. Now, VS2008 changed a little bit about how overloading is done, and with each year we move farther away from COM based interfaces (such as the VBScript currently supported by HomeSeer) and so it is more feasible to do overloading without breaking anything. As such, in creating HS3 and wanting to have previous procedures still work while moving to new ones, I have done a LOT of overloading. So, it is coming now - it is not that we did not want to do it, it was that there were some small issues in doing it pertaining to some of the older technologies still being supported to interface with HomeSeer and the development environment.
                    We still cannot overload a procedure when the parameter types are the same, and for some procedures that DOES make it quite difficult. In fact, there are some overloads that have some parameters required to be provided when normally they would not be, just so the prototype for the overload would appear different from the others.
                    Rick Tinker (a.k.a. "Tink")
