Go Back   HomeSeer Message Board > Ultilities (Plug-ins) > Utilities Discussion > Keyboard and Mouse Sensor Plug-in (3P)
Keyboard and Mouse Sensor Plug-in (3P) Keyboard / Mouse plug-in
Old March 19th, 2016, 04:07 PM
sparkman's Avatar
sparkman sparkman is offline
Remote KMS client crashes on W10
Hi spud,
I've had a few crashes of a remote instance on a W10 device:
- System
  - Provider
   [ Name]  .NET Runtime
  - EventID 1026
   [ Qualifiers]  0
   Level 2
   Task 0
   Keywords 0x80000000000000
  - TimeCreated
   [ SystemTime]  2016-03-19T20:10:17.000000000Z
   EventRecordID 7672
   Channel Application
   Computer Spengler
   Security
- EventData
   Application: HSPI_KMS.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.NullReferenceException Stack: at System.Runtime.Remoting.Messaging.LogicalCallContext.PropagateIncomingHeadersToCallContext(System.Runtime.Remoting.Messaging.IMessage) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(System.Runtime.Remoting.Proxies.MessageData ByRef, Int32) at HomeSeerAPI.IHSApplication.WriteLog(System.String, System.String) at HSPI_KMS.Logger.Log(System.String, ELogLevel) at HSPI_KMS.KMSApp.OnSensorStatusReport(System.Object, System.EventArgs) at HSPI_KMS.Sensor.UserInputReceived() at HSPI_KMS.Sensor.MouseMoved(System.Object, MouseKeyboardActivityMonitor.MouseEventExtArgs) at MouseKeyboardActivityMonitor.MouseHookListener.InvokeMouseEventHandlerExt(System.EventHandler`1<MouseKeyboardActivityMonitor.MouseEventExtArgs>, MouseKeyboardActivityMonitor.MouseEventExtArgs) at MouseKeyboardActivityMonitor.MouseHookListener.ProcessMouseMove(MouseKeyboardActivityMonitor.MouseEventExtArgs ByRef) at MouseKeyboardActivityMonitor.MouseHookListener.ProcessCallback(Int32, IntPtr) at MouseKeyboardActivityMonitor.BaseHookListener.HookCallback(Int32, Int32, IntPtr) at System.Windows.Forms.UnsafeNativeMethods.PeekMessage(MSG ByRef, System.Runtime.InteropServices.HandleRef, Int32, Int32, Int32) at System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32) at System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext) at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext) at HSPI_KMS.KMSApp.RunHookThread() at System.Threading.ThreadHelper.ThreadStart_Context(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) at System.Threading.ThreadHelper.ThreadStart()
Any ideas?
Al
Old March 20th, 2016, 08:33 AM
sparkman's Avatar
This mostly seems to happen when the w10 system comes ot of sleep/suspend mode.
Cheers
Al
Old March 21st, 2016, 12:14 PM
spud's Avatar
spud spud is offline
Moderator
This kind of exception is usually raised when the plugin can't communicate with HS, but I don't understand why it makes the plugin crash, it should only log an error.
I will try to reproduce and debug it.
Old March 21st, 2016, 01:53 PM
sparkman's Avatar
Old March 22nd, 2016, 10:12 AM
Kaje's Avatar
Kaje Kaje is offline
Seer Plus
I'm not getting W10 crashes but sometime in the last couple of weeks (aka a W10 update I'm sure) all of a sudden the mouse control goes bonkers. I disable KMS and it runs fine.
More than happy to help you troubleshoot if you want to tell me what to monitor or look for.
Ken J.
Old November 18th, 2017, 03:34 PM
tahl tahl is offline
Seer Plus
I'm getting the same thing ... what's the solution
I cannot find a pattern but every couple of days KSM crashes on Windows 10 Pro. I've tried running it in both "console" mode and not. This is a remote instance and it not the machine with HS. I have version 3.0.0.5.
It's not usable if I can't rely on it of course. It turns my monitor on among other things.
I have another problem which I will post separately.
Tahl
Old November 20th, 2017, 04:29 PM
spud's Avatar
Moderator
Tahl
check my answer in the other thread.
HSTouch Client Crashes with video now thymer HS3Touch Clients - Android 5 December 8th, 2015 10:38 AM
client crashes on startup zimmer62 Bluetooth Connector 5 October 14th, 2008 09:21 AM
Bluetooth client crashes... Moskus Bluetooth Connector 6 August 7th, 2008 09:33 AM
Speaker Client Crashes on startup fran_joel HS2 / HSPRO 4 June 6th, 2007 10:04 PM
Bluetooth Client crashes on MCE2005 system danes75 Bluetooth Connector 10 December 15th, 2006 11:15 PM
