For the most part the plug-in has been working ok. There was at least one instance where the plug-in lost connection with the hub and I was not able to recover. I had to go to plug-in manager and disable the plug-in and then re-enable it again. The other times it disconnected after a short period of time relatively speaking it would reconnect automatically. This one particular time it did not reconnect automatically or manually. The Hub was connected to my WiFi just fine. Was able to access the Hub with phone app multiple times when plug-in disconnected permanently. I have included the log file so that you can take a look see. Let me know what you think. Maybe one of the timing settings in the plug-in settings screen needs to be tweaked. Not sure. Thanks again for your help !!!!! Rick
