Please post your feature requests here.
SurveillanceStation plug-in - Feature requests
Last time I checked the API documentation wasn't updated.
Once I have the necesarry API calls, implementation is easy. I'm afraid I don't have time to debug how the web-based application is working ...
[EDIT]
Seems like a new api was released:
https://global.download.synology.com...b_API_v2.7.pdf
Give me some time to implement this properly. My agenda is quite full at the moment
[/EDIT]Last edited by kriz83; February 1, 2018, 03:34 AM.
Surveillance Station on QNAP
I currently have 8 cameras network connected to a QNAP TS-453 Pro. I have full time low resolution and motion alerted high resolution recording in place. I would like to be able to integrate some of my SS functionality with my Homeseer capabilities and maybe further extend things by using IFTTT to link actions between Homeseer and my Abode alarm system.
Do you have any plans of providing support for QNAP?
I saw this plugin is called "Surveillance Station" and probably incorrectly assumed it was for QNAP Surveillance Station" A bit more reading seems to show this is for Synology Surveillance Station. I assume this plugin isn't QNAP Surveillance Station compatible then?
NathanHS 3.0.0.435 (PRO)
Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
http://www.kazteel.com/
[EDIT]
[/EDIT]
