I am by no means a syslog guru, but to see entries in the syslog section of this plugin I had to configure each source device with the IP of the HS3 server
Pushing data to third party Syslog service
OK.
1. Nothing sends syslog info unless it has the ability and you have it configured to do so.
2. Should be answered in #1.
3. I'm not entirely clear on this one. In this instance UltraLog has a syslog server. This means that it can receive and log logs from other software that can send logs to a syslog server.
4. See #3.
5. To make it work all you need is software that has remote logging capabilities. If you don't have something that can transmit to a syslog server then it's of no use to you whatsoever.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by ewkearns View Post.....
Any explanation would be greatly appreciated....
Every computer generates logs. Windows has the Event View, Unix has logs as files under /var/logs/ (typically). This is also true with network devices, e.g. routers, managed switches, wi-fi routers, firewall, etc. Each device provides a way to view these logs. They also purge their logs so as not to keep too much stored.
If you have the need to combined those logs, you need to log into each "device" and export those logs and combine them yourself. Syslog offers you the ability to centralize those logs in a single location. Combined into a single "file" or multiple "files" is typically up to how you want it.
If a "device" allows you to configure remote logging, most likely it will use syslog (client). I've include screen captures from my firewall, a wifi router and a managed network switch.
The syslog clients (software), send the log entries to the configured server which must have a syslog daemon (listener - software) running. The syslog daemon is to be configured to tell it where to store each message. (see capture syslog.png)
There are software packages (e.g. graylog) which accept syslog client messages and then can display dashboards, send alert notifications, provide analysis capabilities, etc.
Hope this helps.Len
HomeSeer Version: HS3 Pro Edition 3.0.0.435
Linux version: Linux homeseer Ubuntu 16.04 x86_64
Number of Devices: 633
Number of Events: 773
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
3.0.0.48: EasyTrigger
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.0.87: weatherXML
3.0.1.190: Z-Wave
What Len said...
Syslog is a very simple Unix based logging mechanism that is open.
While Ultralog does a fine job being a Syslog Server for HomeSeer related logging, I do not want all of my non HomeSeer devices logging to Ultralog because it will saturate HS depending on logging traffic.
Regular Ultralog/Syslog utilization:
HomeSeer Log --> UltraLog
What I/and some other are asking: Keep in mind that some of us are seeking a single place where all logs go. Since we anticipate a lot of "log" traffic, we would rather not bog down HomeSeer/Ultralog with this. We will be then using Ultralog as an agent to "relay" all HomeSeer related logs to the 3rd party Syslog server.
HomeSeerLog --> Ultralog --> Relay to 3rd Party Syslog Server
PFSense --> 3rd Party Syslog Server
WIFI Router --> 3rd Party Syslog Server
All Windows Machines --> 3rd Party Syslog Server
All Unix Boxes --> 3rd Party Syslog Server
Other switches/routers --> 3rd Party Syslog Server
I hope this makes sense. For more information on Syslog see https://en.wikipedia.org/wiki/SyslogHomeSeer 2, HomeSeer 3, Allonis myServer, Amazon Alexa Dots, ELK M1G, ISY 994i, HomeKit, BlueIris, and 6 "4k" Cameras using NVR, and integration between all of these systems. Home Automation since 1980.
Thanks guys, I’m really beginning to understand the limitations of trying to do this on Windows. What appears to be a simple *nix matter is apparently convoluted into an exercise to challenge Level 99 Windows IT gurus that are able to leap into their pants… both legs at one time.
A vignette into the Microsoft method is here and appears to involve winrm and wecutil:
https://msdn.microsoft.com/en-us/lib...(v=ws.11).aspx
https://msdn.microsoft.com/en-us/lib...(v=vs.85).aspx
I, also, ran across Graylog, which excited me quite a bit, until I found the following caveat on their website:
“Unfortunately there is no supported way to run Graylog on Microsoft Windows operating systems even though all parts run on the Java Virtual Machine. We recommend to run the virtual machine appliances on a Windows host. It should be technically possible to run Graylog on Windows but it is most probably not worth the time to work your way around the cliffs.”
Graylog
https://www.graylog.org/
So, I think my time is probably going to be more wisely spent with pfSense…. and the firewall that reasonably needs to come first.
Thanks, again, for the collective aid and support….
PS
Anybody that can figure out how to aggregate logs on a Windows network, in a simple and understandable manner, is probably doing the IT equivalent of creating a better mousetrap!HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Home Assistant 2024.3
Enabled Plug-Ins
This is the big issue with closed systems.
Have a look at NXLog (https://nxlog.co/products/nxlog-community-edition) and see if that fits your windows based needs. I have this earmarked for the 1 windows "server" (always on windows 8.1 desktop - ex-HS3 computer) at home. I have not yet done the analysis to see if there is any value in sending the windows event logs to my syslog/graylog yet.
Won't help with HS3 logs to syslog however.Len
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.1.190: Z-Wave
Originally posted by Kerat View PostYea, I am working to get a syslog implemented. I have my firewall (PFSense) hosting a syslog server and just about have the firewall log moved over. Is there an existing plugin that allows the HS3 log to be transmitted to a syslog server?
If you have HS3 on linux and have Perl installed, here is my hack.
I have the following Perl script on my HS server.
Code:#!/usr/bin/perl use Net::Syslog; # flush after every write #$| = 1; while (my $data = <STDIN>) { chomp $data; $data =~ s/\r//g; my $priority = 'informational'; print "$priority\t$data\n"; # write to remote syslog. my $syslog = new Net::Syslog(Facility => 'local4', SyslogHost => '192.168.1.24', Name => 'homeseer', ); $syslog->send("$data", Priority => "$priority"); }
Code:sudo mono HSConsole.exe --log | perl /usr/HomeSeer/scripts/syslog.pl
Code::programname, isequal, "homeseer" /var/log/homeseer.log :programname, isequal, "mono" /var/log/homeseer.log & stop
Len
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.1.190: Z-Wave
It may be that the latest Windows is the kiss of death. From the NXLOG website:
"Supports many different operating systems such as Linux (Debian, Redhat, Ubuntu), BSD, HP-UX, IBM AIX, Solaris, Android and also Microsoft Windows (from XP through 2012) so you don't need a different collector/agent for that other platform."
So.... it sounds like Windows 10 is left out....HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Enabled Plug-Ins
Originally posted by ewkearns View PostIt may be that the latest Windows is the kiss of death. From the NXLOG website:
update: just installed NXLog on my a windows 10 pro desktop without issues. It flooded my syslog server with the following.....
Code:Dec 11 23:45:45 desktop MSWinEventLog#0112#011System#01133#011Mon Dec 11 23:45:45 2017#0111014#011Microsoft-Windows-DNS-Client#011NETWORK SERVICE#011Well Known Group#011Warning#011desktop#011N/A#011#011Name resolution for the name wpad timed out after none of the configured DNS servers responded.#0117551#015 Dec 11 23:46:01 desktop MSWinEventLog#0111#011Application#01134#011Mon Dec 11 23:46:01 2017#01115#011SecurityCenter#011N/A#011N/A#011Information#011desktop#011N/A#011#011Updated Symantec Endpoint Protection status successfully to SECURITY_PRODUCT_STATE_ON.#01112024#015
PHP Code:<Input in>
Module im_msvistalog
# For windows 2003 and earlier use the following:
# Module im_mseventlog
ReadFromLast TRUE
<QueryXML>
<QueryList>
<Query Id='1'>
<Select Path='Application'>*</Select>
<Select Path='Security'>*[Security/Level=4]</Select>
<Select Path='System'>*</Select>
</Query>
</QueryList>
</QueryXML>
</Input>
Len
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.1.190: Z-Wave
Originally posted by lveatch View PostI *think* that's what this thread is about. Having UltraLog HSPI forward the HS3 database log entries to an central syslog daemon.
I modified HS3's go script as follows:
My central syslog VM (192.168.1.24) is configured to send all "homeseer" and "mono" log entries to /var/log/homeseer.log. I have a
There is only one limitation to this. I can't issue the console's command line to stop homeseer. I have to do it via the web UI.
This is sweet. I will give this a whirl this weekend.
This is what the log output looks like on my syslog receiver:
Code:Dec 17 10:14:46 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Info, Message=Plugin UltraLog3 with instance: has disconnected#015 Dec 17 10:15:00 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Log Maintenance, Message=81 records, selected by date/time, were removed from the log database.#015 Dec 17 10:15:00 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Log Info, Message=The log database is currently 2.31MB in size.#015 Dec 17 10:15:25 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Z-Wave, Message=Device: Node 2 Z-Wave Gallons Set to 843.3 (843.3 Gallons)#015 Dec 17 10:16:06 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Info, Message=Plugin UltraLog3 has connected. IP:127.0.0.1:57933#015 Dec 17 10:16:25 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Z-Wave, Message=Device: Node 2 Z-Wave Water Notification Set to NOTIFICATION for type Water Notification, Event: No Event#015 Dec 17 10:18:14 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Info, Message=Plugin UltraLog3 with instance: has disconnected#015 Dec 17 10:19:40 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Info, Message=Plugin UltraLog3 has connected. IP:127.0.0.1:58063#015 Dec 17 10:21:49 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Device Control, Message=Device: Node 2 Z-Wave Gallons to Reset Accumulated Values (0) by/from: CAPI Control Handler#015 Dec 17 10:21:49 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Z-Wave, Message=Device: Node 2 Z-Wave Gallons Set to 0#015 Dec 17 10:22:10 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Z-Wave, Message=Device: Node 2 Z-Wave Gallons Set to 0.1 (0.1 Gallons)#015 Dec 17 10:22:10 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Z-Wave, Message=Device: Node 2 Z-Wave Water Notification Set to NOTIFICATION for type Water Notification, Event: Water Flow Alarm#015 Dec 17 10:22:33 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Warning, Message=Interface UltraFlowMeter3 is running as a trial, 6 days remaining.#015 Dec 17 10:22:33 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Info, Message=Plugin UltraFlowMeter3 has connected. IP:127.0.0.1:58725#015 Dec 17 10:22:34 mac-mini-dev HomeSeer3[904]: Priority=0, errorCode=0, Source=HomeSeer3, Type=Plug-In, Message=Finished initializing plug-in UltraFlowMeter3#015
Last edited by Ultrajones; December 17, 2017, 10:24 AM.Plug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
