Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > MyHS Remote Access Service
MyHS Remote Access Service Discussions regarding myHomeSeer Remote Access Service
  #21
Old December 28th, 2017, 10:43 AM
Sheriff Sheriff is offline
Windows 10
HS3Pro on Windows 10
One install with 2 Ethernet Z-nets
2nd install with 1 Zstick
300 devices, 250 events, 8 scripts
5 CT-100 tstats
Serial IT-100 interface to DSC Panel with 8 wired zones
18 Fortrezz water sensors & two valve controls
Serial Rain8Net Pro with 8 zones
  #22
Old December 28th, 2017, 04:55 PM
Kerat Kerat is offline
Originally Posted by Sheriff View Post
Windows 10
Is it pro or home?
  #23
Old December 28th, 2017, 05:03 PM
farfromuman farfromuman is offline
What I have observed is that HS will bind to anything other than the local default IP in windows. For this reason I had to uninstall Hyper-V since it has its own virtual adapter and private network. Local access started working after this. I have also seen HS bind to my VPN adapters. This happens even though the web server is bound to local IP.
  #24
Old December 28th, 2017, 06:01 PM
Rupp's Avatar
Rupp Rupp is offline
You should need to use the binding option at all unless you have multiple network cards or running in a virtual environment.
-Rupp
  #25
Old December 28th, 2017, 08:04 PM
Kerat, it is windows10 home. It looks like I am the only user and hold admin rights, but not positive.
  #26
Old December 28th, 2017, 08:12 PM
Kerat, I got logged in as admin and now have windows firewall advanced security open. Let me see if I can figure this out before you waste anymore time on me. I'll let you know shortly.
  #27
Old December 28th, 2017, 08:29 PM
Kerat, I set up the rule and double checked settings, all correct and enabled. Turn on public firewall, didn't work. Turn off pubic firewall only (private still on), I can get in. I am noticing that only the public network shows to be connected to my LAN, while the private network is not connected to anything...is that typical?
  #28
Old December 28th, 2017, 08:39 PM
  #29
Old December 28th, 2017, 09:01 PM
Kerat, you might have some catching up to do, see the several messages before. I noticed in the inbound rules that there are two rules for HS3 private and 2 rules for HS3 public. As to each of the private rules, both allowed access for HS3.exe. However, one allowed the connections, while the other blocked the connections, one for udp and one for TCP. When I changed the blocked rule to allow, suddenly I have access. The same was true of the two public rules, one allowed connections and one blocked connections. Are these typical rules that should be allowed? Well it seems to have fixed my problem, I don't want to open up my computer unreasonably.
  #30
Old December 28th, 2017, 09:28 PM
Interesting, was the UDP inbound rule blocked in both the private and public firewall zone?
  #31
Old December 28th, 2017, 10:34 PM
I did not look closely, but I think the public rules of both UDP and TCP were turned off.
  #32
Old December 29th, 2017, 12:05 AM
Cant connect locally
Ok, so windows firewall divides rules by network types (domain (if you have it, it is because you are on a corporate network and are connected to a domain), private (your home network, and public (networks you don't trust like guest networks and only need access to the Internet) to determine what to allow through the firewall and when. This is meant for laptops and tablets that move around and may connect to guest networks where you would not want the computer to be exposed to potential threats.
It sounds like your computer put your home network in the public network type and this broke connectivity on your local LAN. See the following link for a quick run down on how to change network types.
https://tinkertry.com/how-to-change-...lic-to-private
  #33
Old December 29th, 2017, 12:21 AM
Kerat, thank you for walking me through this, I was at my wits end. For your patient help, I award you the Elias Medal of Service (Elias helps me with various things...you should feel honored).
  #34
Old December 29th, 2017, 12:26 AM
I am glad you got it worked out, and thank you for the prestigious honor.
Logout not working locally mnsandler HS3 / HS3PRO Discussion 19 July 6th, 2017 02:29 PM
Tasker not connecting locally mikee123 Tasker Plugin (3P) 4 July 11th, 2016 03:39 PM
PANIC! Changed ISP and router, HStouch cannot connect LOCALLY - Solved! Moskus HSTouch™ 6 July 8th, 2013 08:20 AM
vb script runs locally but not in event TeleFragger HS2 / HSPRO 9 November 15th, 2007 07:34 PM
Locally muting a PZM-11 Bill Brower HomeSeer General Discussion Area 12 June 29th, 2005 02:18 PM
