For some reason, I'm not seeing where to install HS3 as a service. Is this not available anymore?
HS3 Service - Running as a service is not built into HS3
Originally posted by Sireone View PostFor some reason, I'm not seeing where to install HS3 as a service. Is this not available anymore?
This just Beta or the release version as well??
If the release version, it'll be back to FireDaemon for me...
RobHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
We found that running HS2 as a service came with a number of issues with plugins and such.
As a result, we decided not to support this option for HS3.
That being said, it is possible to run HS3 as a service in Windows
http://support.microsoft.com/kb/251192
We make no guarantees on how well this might work.Wade
"I know nothing... nothing!"
Originally posted by beerygaz View PostAm I wrong in assuming the Linux version will not be a daemon then either? Will it require a user session / GUI to run?HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
I always assumed you needed it to run as a service to make sure that it would always start up on a reboot, and not have to be "logged in" to run it. Is that not the case? I can't imagine people aren't expecting that kind of functionality. This is a smart group with high expectations. I am clearly missing out on something cooler. What is it??? Is there another way to do this without having to have a user account be logged in all the time?
I've been running as a service using Fire Daemon from day 1 for just that reason alone... When I make the move to HS3, I'll be running HS3 the same way.
HS3 Service
I think the only challenge with running as a service was it you were using speech recognition or the speaker client on the server. Access to audio services required an active user session.
I too would far prefer a headless server knowing the service would reliably start as a service on every boot. I don't want to run my HA system on a desktop OS.Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
So, I used sc.exe and it successfully added the service. But when I start the service, it eventually dies saying something to the effect that "The service did not respond to the start or control request in a timely fashion".
Oddly, I was able to access the HS3 web interface and navigate it for about 15 seconds, but then it stopped. So, I think the new service started correctly, but Windows didn't see it that way, and killed it.
I set it up using this
C:\Users\Administrator>sc create HS3Service binPath= "C:\Program Files (x86)\HomeSeer HS3\HS3.exe"
Thoughts?
No "auto start" on boot in HS3
I just upgraded (paid) to HS3 and have been running HS2 as a service for 7 years. Seems to me that a lack of an auto-start feature on a home control product is a pretty major oversight.
This thing controls core functions of the home. My furnace and hot water heater do not require manual intervention when restarted. When a Light is in the on position and the power goes out and restarts, the light returns to "on."
I am not suggesting that supporting the service mode is the solution, but an auto re-start without requiring a manual log-in and application start is an absolute requirement.
Also, I accidentally logged out of my computer with HS3 running, forgetting that this will shut down the application too.
Simply unacceptable.
HS3 Refund
If they won't fix this, I am going to request a refund on my upgrade. This is a major architectural oversight, in my opinion.
This is "Home Automation" software. Where in the process of having to "manually log-in and launch the application" is "automation" provided?
The recommended remedy offered is a wonky (technical term) work around and unnacceptable.
