I decided to add verion incrementation to a plugin written as an exe. It would not load by homeseer. I put the version number back where it was and it loads okay. I suspect that when homeseer registers the plug in, it somehow registers the version number with it, IMHO that is not a good idea. It does not allow a developer to maintain version control. I would much rather that a newer version was automatically re-registered. Rich ?
Plug in Versions
HS does nothing with the version number. It calls "CreateObject" on your program ID, so the file must be registered properly with Windows. You probably should unregister the EXE first with /unregserver, then re-register with /regserver. The updater takes care of this for you.
-Rich
HomeSeer Technologies LLC
