Installed AD2USB and vista alarm home seer plug in. I can see updated alarm system status on home seer. My zones all work and show. When I set alarm to alarm away using alarm keypad home seer updates system status with no problem. The problem is when I try to arm, disarm, stay, night stay, etc.. using homeseer it does nothing. For some reason I get all communications from panel but can't send a arm or disarm command from home seer. Some things I have noticed I also have alarm decoder setup on my home seer controller. I can effectively disarm, arm, etc, using alarm decoder keypad. However when vista alarm plug in is enabled hen my alarm decoder no longer works and continuously gets stuck trying to communicate to panel. I assume both vista plug in and alarm decoder are both on same COM.
Please advise what I need to do to fix or figure out why I can't disarm, arm etc. using home seer device.
