Here is a sample of my log. The phone picks up, but nothing is heard. I assume it has something to do with the Audio Device within Way2Call?
Any thoughts?
Jim
Aug-10 10:15:24 AM HSPhone Finished Resetting line: Main
Aug-10 10:15:22 AM HSPhone Muting rings disabled
Aug-10 10:15:22 AM HSPhone Enter WaitForCall, modem: HIPHONE
Aug-10 10:15:22 AM HSPhone Enter OpenLine, line: Main
Aug-10 10:15:22 AM HSPhone Calling hangup for line: Main
Aug-10 10:15:22 AM HSPhone Resetting line: Main
Aug-10 10:15:22 AM HSPhone Resetting from IVR timer
Aug-10 10:15:22 AM Error Reading file in GetMessageLen C:\Program Files (x86)\HomeSeer HS3\messages\2015-08-10_10-15-06.wav Could not find file 'C:\Program Files (x86)\HomeSeer HS3\messages\2015-08-10_10-15-06.wav'.
Aug-10 10:15:20 AM Phone Line 1 Message length: 11 seconds
Aug-10 10:15:20 AM HSPhone Line current drop detected, disconnecting, timer: 13
Aug-10 10:15:06 AM HSPhone Maximum message recording time is set to 30 seconds.
Aug-10 10:15:06 AM Phone Line 1 Starting recording to file: C:\Program Files (x86)\HomeSeer HS3\messages\2015-08-10_10-15-06.wav
Aug-10 10:15:06 AM HSPhone SetupRecord->File: C:\Program Files (x86)\HomeSeer HS3\messages\2015-08-10_10-15-06.wav, CID:Cell Phone Ny/XXXXXXXXXX
Aug-10 10:15:06 AM Phone Line 1 IVR RECORD: RECORD:$DEFAULT_MAILBOX
Aug-10 10:15:06 AM Phone Line 1 Playing wave file over the phone: C:\Program Files (x86)\HomeSeer HS3\phonewaves\beep.wav
Aug-10 10:15:04 AM HSPhone Line: Main Speak: please leave a message at the beep
Aug-10 10:15:03 AM Phone Line 1 Read 462 lines from IVR file C:\Program Files (x86)\HomeSeer HS3\ivr\external_single.txt
Aug-10 10:15:03 AM Phone Line 1 Connected: Main
Aug-10 10:15:03 AM HSPhone Answering call in 4 rings
Aug-10 10:15:03 AM HSPhone Line ringing (line Main), count: 4 ForceAnswer: 0 Normrings: 4
Aug-10 10:15:03 AM TTS Speak ():you have a call from Cell Phone Ny
Aug-10 10:15:03 AM HSPhone gRingStopTime = 8000
Aug-10 10:15:03 AM HSPhone Ring
Aug-10 10:15:00 AM Log Info The log database is currently 24.53MB in size.
Aug-10 10:15:00 AM Log Maintenance 55 records, selected by date/time, were removed from the log database.
Aug-10 10:14:57 AM HSPhone Line ringing (line Main), count: 3 ForceAnswer: 0 Normrings: 4
Aug-10 10:14:57 AM TTS Speak ():you have a call from Cell Phone Ny
Aug-10 10:14:57 AM HSPhone gRingStopTime = 8000
Aug-10 10:14:57 AM HSPhone Ring
Aug-10 10:14:51 AM HSPhone Line ringing (line Main), count: 2 ForceAnswer: 0 Normrings: 4
Aug-10 10:14:51 AM TTS Speak ():you have a call from Cell Phone Ny
Aug-10 10:14:51 AM HSPhone gRingStopTime = 8000
Aug-10 10:14:51 AM HSPhone Ring
Aug-10 10:14:48 AM TTS Speak ():you have a call from Cell Phone Ny
Aug-10 10:14:48 AM HSPhone So far, no match, call has CID, but is not private or out-of-area, using default handling
Aug-10 10:14:48 AM HSPhone Searching for a match on CID. CID Num is: XXXXXXXXXX
Aug-10 10:14:48 AM Phone Line 1 Caller ID Name: Cell Phone NY Number: XXXXXXXXXX
Aug-10 10:14:48 AM HSPhone CID Name: Cell Phone NY CID Number: XXXXXXXXX
Aug-10 10:14:45 AM HSPhone Line ringing (line Main), count: 1 ForceAnswer: 0 Normrings: 4
Aug-10 10:14:45 AM HSPhone gRingStopTime = 8000
Aug-10 10:14:45 AM HSPhone Ring
Aug-10 10:14:45 AM Phone Line 1 Clearing old Caller ID information
Aug-10 10:14:31 AM HSPhone Finished Resetting line: Main
Aug-10 10:14:29 AM HSPhone Muting rings disabled
Aug-10 10:14:29 AM HSPhone Enter WaitForCall, modem: HIPHONE
Aug-10 10:14:29 AM HSPhone Enter OpenLine, line: Main
Aug-10 10:14:29 AM HSPhone Calling hangup for line: Main
Aug-10 10:14:29 AM HSPhone Resetting line: Main
Aug-10 10:14:29 AM HSPhone Resetting from IVR timer
Aug-10 10:14:29 AM Error Reading file in GetMessageLen C:\Program Files (x86)\HomeSeer HS3\messages\2015-08-10_10-14-08.wav Could not find file 'C:\Program Files (x86)\HomeSeer HS3\messages\2015-08-10_10-14-08.wav'.
Aug-10 10:14:27 AM Phone Line 1 Message length: 16 seconds
Aug-10 10:14:27 AM HSPhone Line current drop detected, disconnecting, timer: 18
Aug-10 10:14:08 AM HSPhone Maximum message recording time is set to 30 seconds.
Aug-10 10:14:08 AM Phone Line 1 Starting recording to file: C:\Program Files (x86)\HomeSeer HS3\messages\2015-08-10_10-14-08.wav
Aug-10 10:14:08 AM HSPhone SetupRecord->File: C:\Program Files (x86)\HomeSeer HS3\messages\2015-08-10_10-14-08.wav, CID:New York/***********
Aug-10 10:14:08 AM Phone Line 1 IVR RECORD: RECORD:$DEFAULT_MAILBOX
Aug-10 10:14:08 AM Phone Line 1 Playing wave file over the phone: C:\Program Files (x86)\HomeSeer HS3\phonewaves\beep.wav
Aug-10 10:14:05 AM HSPhone Line: Main Speak: please leave a message at the beep
Aug-10 10:14:04 AM Phone Line 1 Read 462 lines from IVR file C:\Program Files (x86)\HomeSeer HS3\ivr\external_single.txt
Aug-10 10:14:04 AM Phone Line 1 Connected: Main
Aug-10 10:14:04 AM HSPhone Answering call in 4 rings
Aug-10 10:14:04 AM HSPhone Line ringing (line Main), count: 4 ForceAnswer: 0 Normrings: 4
Aug-10 10:14:04 AM TTS Speak ():you have a call from York New
Aug-10 10:14:04 AM HSPhone gRingStopTime = 8000
Aug-10 10:14:04 AM HSPhone Ring
Any thoughts?
Jim
