I used to copy files between HS3 computers using SSH then went to sharing data directories and today playing a bit with using Mosquitto.
Personally I have never needed to reboot or reset PFSense. You do not want to power it off cold as you will corrupt the files running.
Google the command line for restarting PFSense.
I have historically had issues with the older combo firewalls that would need to reboot to get them going again because of the SOHO firmware that never was updated.
