Not seeing any device
Originally posted by spud View Postyou need to install flite:
Code:apt-get install flite
I just did a "sudo apt-get install flite" and now the test buttons work!
Is there any way to get a nicer sounding TTS engine? I know someone asked you about the Google Assistant one in a different post?
Here is some threads discussing alternatives to flite:
https://forums.homeseer.com/showthread.php?t=178867
https://forums.homeseer.com/showthread.php?t=175012
Originally posted by spud View PostI will see if I can make the Google Assistant voice to work.
Look forwards to seeing it work with the Google Assistant... Fingers crossed you can make it happen!
Originally posted by spud View PostHST is working on the updater, and they messed up the Chromecast plugin on Linux. The windows version is installed instead of the Linux one. They are working on a fix.
You should manually delete the content of bin/Chromecast (especially Mono.Zeroconf.Providers.Bonjour.dll ) and then install manually from https://forums.homeseer.com/showthread.php?t=191010 or wait for the updater to be fixed.
sorry for the inconvenience
I have avahi-daemon installed and running:
root@homeseer:~# service avahi-daemon status
● avahi-daemon.service - Avahi mDNS/DNS-SD Stack
Loaded: loaded (/lib/systemd/system/avahi-daemon.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2018-03-11 21:45:16 MDT; 21h ago
Main PID: 26131 (avahi-daemon)
Status: "avahi-daemon 0.6.32 starting up."
Tasks: 2 (limit: 4915)
Memory: 1.1M
CPU: 5.413s
CGroup: /system.slice/avahi-daemon.service
├─26131 avahi-daemon: running [homeseer.local]
└─26138 avahi-daemon: chroot helper
Mar 11 21:45:16 homeseer avahi-daemon[26131]: Successfully dropped remaining capabilities.
Mar 11 21:45:16 homeseer avahi-daemon[26131]: No service file found in /etc/avahi/services.
Mar 11 21:45:16 homeseer avahi-daemon[26131]: Joining mDNS multicast group on interface enp1s0.IPv6 with address xxxx::xxxx:xx:xxxx:xxxx.
Mar 11 21:45:16 homeseer avahi-daemon[26131]: New relevant interface enp1s0.IPv6 for mDNS.
Mar 11 21:45:16 homeseer avahi-daemon[26131]: Joining mDNS multicast group on interface enp1s0.IPv4 with address xxx.xxx.xxx.xxx.
Mar 11 21:45:16 homeseer avahi-daemon[26131]: New relevant interface enp1s0.IPv4 for mDNS.
Mar 11 21:45:16 homeseer avahi-daemon[26131]: Network interface enumeration completed.
Mar 11 21:45:16 homeseer avahi-daemon[26131]: Registering new address record for xxxx::xxxx:xx:xxxx:xxxx on enp1s0.*.
Mar 11 21:45:16 homeseer avahi-daemon[26131]: Registering new address record for xxx.xxx.xxx.xxx on enp1s0.IPv4.
Mar 11 21:45:17 homeseer avahi-daemon[26131]: Server startup complete. Host name is homeseer.local. Local service cookie is xxxxxxxxx.
Here is the output of my Chromecast directory:
root@homeseer:~# ls -alh /opt/HomeSeer/bin/Chromecast/
total 1008K
drwxr-xr-x 2 root root 4.0K Mar 11 21:40 .
drwxr-xr-x 6 user root 4.0K Mar 11 21:40 ..
-rw-r--r-- 1 root root 39K Sep 14 07:54 avahi-sharp.dll
-rw-r--r-- 1 root root 212 Sep 14 07:54 avahi-sharp.dll.config
-rw-r--r-- 1 root root 265K May 3 2017 Google.Protobuf.dll
-rw-r--r-- 1 root root 14K Sep 14 07:54 Mono.Zeroconf.dll
-rw-r--r-- 1 root root 15K Sep 14 07:54 Mono.Zeroconf.Providers.Avahi.dll
-rw-r--r-- 1 root root 458K Jun 13 2016 Newtonsoft.Json.dll
-rw-r--r-- 1 root root 152K Feb 28 08:21 SharpCaster.dll
-rw-r--r-- 1 root root 14K Sep 30 2016 Sockets.Plugin.Abstractions.dll
-rw-r--r-- 1 root root 26K Sep 30 2016 Sockets.Plugin.dll
Plugin is 3.0.0.16 and shows an OK status in the web interface.
The following is logged when I enable the plugin:
Mar-12 7:26:00 PM Chromecast ERROR System.Exception: No Zeroconf providers could be found or initialized. Necessary daemon may not be running. at Mono.Zeroconf.Providers.ProviderFactory.GetProviders () [0x00264] in <350cc7bac8c6475198007c91dd299fbc>:0 at Mono.Zeroconf.Providers.ProviderFactory.get_DefaultProvider () [0x0000e] in <350cc7bac8c6475198007c91dd299fbc>:0 at Mono.Zeroconf.Providers.ProviderFactory.get_SelectedProvider () [0x0000f] in <350cc7bac8c6475198007c91dd299fbc>:0 at Mono.Zeroconf.ServiceBrowser..ctor () [0x00008] in <350cc7bac8c6475198007c91dd299fbc>:0 at HSPI_Chromecast.ChromecastDiscoverer.Start () [0x00000] in <025a3af8921b4e25b1bea41b88c904d4>:0 at HSPI_Chromecast.ChromecastApp.b__57_0 () [0x0004a] in <025a3af8921b4e25b1bea41b88c904d4>:0
Mar-12 7:26:00 PM Plug-In Finished initializing plug-in Chromecast
Mar-12 7:26:00 PM Chromecast INFO Chromecast version 3.0.0.16
Mar-12 7:26:00 PM Info Plugin Chromecast has connected. IP:127.0.0.1:54852
Mar-12 7:26:00 PM Plug-In Interface Chromecast is running as a trial, 21 days remaining.
Any thoughts on what I can try?
Thanks a lot!
-Landon
Originally posted by harshl View PostI tried following the above steps to manually install, but I am still not finding any devices.
Memory: 1.1M
CPU: 5.413s
total 1008K
Thanks a lot!
-Landon
what's your mono version?
OS is - Ubuntu 17.10 (GNU/Linux 4.13.0-36-generic x86_64)
Mono Version is -
Mono JIT compiler version 4.6.2 (Debian 4.6.2.7+dfsg-1ubuntu1)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: amd64
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen
It was installed with mono-complete as I recall.
-Landon
Originally posted by harshl View PostSorry tried to be complete, but missed those obvious items.
Mono Version is -
TLS: __thread
SIGSEGV: altstack
Architecture: amd64
Disabled: none
Misc: softdebug
GC: sgen
-Landon
Another thing you can try is to manually add one of your chromecast in the ini file like explained at the end of the first post of the user guide, to see if you have other problems with the plugin or if it is limited to avahi.
