You have it set up correctly. The rain gauge does not reset. The Oregon receivers do that, but with HomeSeer you will need to do it yourself. You will need to create a couple of events and scripts. I have the scripts if you are interested. I switched over to using ACRF2 but I am going to switch back to xapmcsrf for the rain gauge.
The Oregon rain gauge has a little lever that flips back and forth based on rain flow through the unit. This is the actual count, for some 1wire and other sensors, this is the only data available. With the Oregon rain gauge, it is interesting, but I can't think of anything to use it for, since the rain gauge computes and transmits rain rate and rain total.
Bill
Bill
