How do you use this plugin?
    I just installed the trial and I don't get it.
    I created a group. Entered some values but I can't figure out what to do next. I copied the example code in the help doc and replaced "Morning Phrases with my group name and tried to run it from the control panel but nothing happened. The log tells me there is a syntax error.
    For the record this is exactly what I ran:
    &Dim myRandomValue As String = ""
        myRandomValue = hs.PluginFunction("BLRandom", "", "RandomizeGroup", {"I Entered"})
        hs.writelog("Info", "The new random value is: " & myRandomValue)
        myRandomValue = Nothing
    I'm assuming I'm leaving something out.
    Also, can I put BLSpeech special processing tags in front of my values? Is that the proper way to do it?
    Originally posted by rprade
    Where are you running this from (script, event action)?
    I have a vb.net script that does this:
    I run in the startup script for HS3
    Sub Main(byval param As Object)
    	Dim message As String = hs.PluginFunction("BLRandom", "", "RandomizeGroup", new Object(){"HomeSeer Startup Phrases"})
    	hs.Speak(message, True)
    	message = Nothing
    End Sub
    Cheers,
    Bob
      The control panel directly, under tools.
        Yea do not use that. It does not handle vb.net code properly.
        Use a .vb script file
        Cheers,
        Bob
          So I copied your code, made a xxx.vb script with it changing startup phrases to the name of my group and at least does something now. It plays the TTS but the BLSpeech special processing tags I specified in my values aren't respected. I had been using Jeff's Random Phrase plugin before and the same happened with it, which is why I'm trying BLRandom. Is there a way to use the BLSpeech special processing tags with BLRandom?
            Capture me a debug log from both plugins on what you are doing.
            Post both logs here zipped so I can see what is going on.
            Cheers,
            Bob
              Here you go.
              In the mean time I actually had it work twice in a row. Without changing anything. It then failed the next several attempts though. So then I tried it again with the Random Phrase plugin and after repeated attempts I also got it to work that way once. So I'm beginning to think that if I'm not doing something very very wrong I may have uncovered a bug in either BLSpeech or HS3.
              So I'm also attaching a BLSpeech log from when it fails with the Random Phrase plugin.
              Thanks for looking into it!
                OK I will have a look as soon as I can and let you know
                Cheers,
                Bob
                  I do not see any errors at all.
                  I see that BLRandom picked this phrase for speaking:
                  {speaker=Kitchen,source=2,volume=50} Welcome home Colin
                  BLSpeech looks like it processed it fine. According to BLSpeech it spoke it. Did it speak it?
                  Can you show me how you ran the whole thing?
                  I will then run the same thing here and see what happens
                  Cheers,
                  Bob
                    Hmmmm. The plot thickens.
                    Maybe it's a BLRussound issue? What happens, with both BLRandom and Random Phrase, is that the Russound zone turns on and then back off immediately. The speaker client does indeed show that it spoke what I desired every time. I just can't hear it because the zone isn't on. Which is why I assumed that the special processing tags weren't being followed.
                      Capture a debug log from BLSpeech and BLRussound and attach them zipped.
                      I will then see what is going on
                      Log a ticket on my site for it please so it is easier to track.
                      Attach the debug logs zipped.
                      Attach the script you are using as well
                      Cheers,
                      Bob
                        OK. Done.
                        I was beginning to feel pretty embarrassed. I turned debug logging on and then it worked three times in a row. So I tried with Random Phrase and again, it worked. So I waited a while and then it failed for me. So I turned debug logging on again and managed to get it to fail. All in all I've probably tried to run this event 40 times and it has now succeeded 7 times.
                          Cheers,
                          Bob
                            Great. Thanks for looking into it.
