Blade, since RFXCom now only makes the RFXtrx433E for Oregon Scientific sensors and I use BLRF, can the plugin be updated to fully support it? I don't need it to support the transmit functions, but wanted it to be supported like the REXrec433 is.
Can BLRF Be Updated To The RFXtrx433E?
Jean-Marie G. Vaneskahian
jean@vaneskahian.com
---------------------------------------------------Tags: None
These are the only ones supported by the plugin
https://forums.homeseer.com/showthread.php?t=160715
Perhaps Bert could comment on whether the RFXtrx433E could be supported
Thanks, I did not realize that I could flash the RFXtrx433E with the firmware of the REXrec433. That solves it! Perfect. Thanks!---------------------------------------------------
Will do! The problem seems to be that one single RFXCom receiver is not enough for coverage of all 10 of my Oregon Scientific 10 channel sensors. So I wanted to use 2 receivers with your plugin to get better coverage and I assume your plugin will know that a single message was received event though both receivers might see it?---------------------------------------------------
