I am trying to implement a plugin. I am able to install it. However, when I try to enable it after installation I get the following "plug-in status" "WARNING: Failed getting InterfaceStatus from ... - the interface was not found in the list of active interfaces, the list may need to be refreshed.". In the log I see that the property "Name" was called. After that it says:
Exiting Connect on line ...(Note: this is my message I log)
Plugin has connected. IP:127.0.0.1:[port]
Starting plugin:: Object reference not set to an instance of an object."
What would really help me is know what functions HS3 is calling in my plugin after clicking on the "turn on/enable" switch in HS3. As mentioned above, "Name" seems to be called first followed by "Connect" but I am missing some log entries so something else must be going on.
