OVER_QUERY_LIMIT Error and question
    I started getting the following error:
    Nov-22 14:23:21 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:2LA1:XX.X LO1:-XX.X LA2:XX.X LO2:-XX.X
    I also noticed that if you go the Common Places and try to check the box to enable the Common Place, it un-checks itself. Not sure if this is by design or not so asking.
    Michael
    HS3Pro & HS4Pro on Win2012R2
    Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
    BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
    Just scanned my log. I get quantities of the following errors, some dating back to September:
    Sep-21 11:58:17 PHLocation Error (UpdateUserDevice) Error getting reverse geocode for [148] Lat: xxx Lon:yyy
    Oct-13 16:48:27 PHLocation Error (GetElevationG) Status error: OVER_QUERY_LIMIT
    Oct-21 08:17:29 PHLocation Error (GetReverseGeoG) Status: Error: System.NullReferenceException: Object reference not set to an instance of an object. at g.b(String A_0, String A_1, String A_2)
    Geofencing and tracking otherwize work fine.
    Feature request: Please add to the logging which device is involved as I use several.
      I'm also seeing them.
      RJ_Make On YouTube
        Have you defined a Google Maps API key on the config API's page?
        Paul..
          LOL, Paul I think I'm getting too old to be messing with computers. I didn't think I did, but I just checked and sure enough.. I did set it..
          RJ_Make On YouTube
            Mine went away for a long time but they are back.
            Apr-25 08:06:13 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:1LA1:XX.X LO1:-XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:12 PHLocation (UpdatePlaceDevice) MatrixDist G Typ:W for [669] attempt 1 failed. Retrying in 1s.
            Apr-25 08:06:12 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:2LA1:XX.X LO1:-XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:12 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:1LA1:XX.X LO1:-XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:11 PHLocation (UpdatePlaceDevice) MatrixDist G Typ for [669] attempt 1 failed. Retrying in 1s.
            Apr-25 08:06:11 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:1LA1:XX.X LO1:-XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:10 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:1LA1:XX.X LO1:-XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:09 PHLocation (UpdatePlaceDevice) MatrixDist G Typ:W for [669] attempt 1 failed. Retrying in 1s.
            Apr-25 08:06:09 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:2LA1:XX.X LO1:-XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:09 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:1LA1:XX.X LO1:-XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:08 PHLocation (UpdatePlaceDevice) MatrixDist G Typ for [669] attempt 1 failed. Retrying in 1s.
            Apr-25 08:06:08 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:1LA1:XX.X LO1:-XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:07 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:1LA1:XX.X LO1: -XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:06 PHLocation (UpdatePlaceDevice) MatrixDist G Typ:W for [669] attempt 1 failed. Retrying in 1s.
            Apr-25 08:06:06 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:2LA1:XX.X LO1: -XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:06 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:1LA1:XX.X LO1: -XX.X LA2:XX.X LO2:-XX.X
            Apr-25 08:06:05 PHLocation (UpdatePlaceDevice) MatrixDist G Typ for [669] attempt 1 failed. Retrying in 1s.
            Apr-25 08:06:05 PHLocation Error (GetMatrixDistanceG) Status error: OVER_QUERY_LIMIT for Typ:1LA1:XX.X LO1: -XX.X LA2:XX.X LO2:-XX.X
            Not sure I understand what having a map API does to cause the over query limit error.
            Michael
