Security Mode - Button Release Function
    Hello - First off, thank you very much for the amazing work and responsiveness.
    Would it be possible to add the "button release" command to the main repeater phantom commands? This is the only way to "exit" security mode buttons types.
    I would like to be able to make the lights stay full on until the alarm is disarmed... Right now if you trigger the scene there is no way to turn off the security mode scene as it requires sending a button release command. I just had to manually telnet into my main repeater to type the command LOL.
    The specification is detailed in the essentials software when you highlight "when to use" when selecting security mode under button type on the main repeater.
    Thanks - Tristan
    Can you test the ver. 98, it should work, you will need to click the created devices in the config after updating to the new version
      I haven't tested although this appears to have worked, the new buttons are in place. Thank you!!
