Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > PI-SonosController (3P)
PI-SonosController (3P) Discussion of Sonos Controller Plug-in
Old February 2nd, 2018, 05:22 AM
pyspilf's Avatar
pyspilf pyspilf is offline
Seer Deluxe
About Sonos conditions for an event
Do they work?
When I select "Group Conditions" --> IF --> "Sonos Condition" I get a list box below called "Select Command" and the item it defaults to is "Please select"
When I open this list, no matter what I select, it goes back automatically to "Please select"... so a condition cannot be chosen...
I thought it could be a browser issue, have tried with Chrome, Safari and IE, all show the same behaviour...
Anyone using Sonos conditions in group conditions for an event successfully?
Sandro
HS3 Pro Edition 3.0.0.409| Plug-Ins Enabled: Sonos 3.1.0.22, RFXCOM 30.0.0.36, X10 3.0.0.36, IPThermostat 3.4.5.0, Pushover 3P 0.0.0.37, Blue-Iris 3.1.1.24385, Z-Wave 3.0.1.162, BLML2HS 2.0.28.0 | Win 7 32-bit | Intel Atom D2550 @ 1.86GHz 4GB RAM
Old February 2nd, 2018, 09:59 AM
rprade's Avatar
rprade rprade is offline
OverSeer
Quote:
Originally Posted by pyspilf View Post
Do they work?
Sandro
The Sonos Conditions work fine within a group, but will not work in group conditions. Some plug-ins will work in group conditions and some won’t. I don’t know if the plug-in author has to do something different for conditions to work in group conditions. I don’t use group conditions, so I never noticed until I tested this morning. Easy Trigger Conditions do work in group conditions.
Randy Prade
Aurora, CO
Prades.net
Old February 2nd, 2018, 01:39 PM
pyspilf's Avatar
Seer Deluxe
Thanks a lot Randy. I tried conditions within a single event and it works fine, so I adjusted what I was going to do to work that way...
Had no idea of what you mentioned about it possibly being something that needs to be developed specifically.
Cheers!
Sandro
HTML code is Off
Man Trig Event - does Run Only if other Event Conditions are True apply ? chargernut69 HS3 Event Clinic 16 February 5th, 2018 09:27 AM
Event Conditions Ignored? Eddiie BLRadar (3P) 1 March 6th, 2012 06:32 AM
Conditions on an event rschein HS2 / HSPRO 2 December 7th, 2010 09:24 AM
Event conditions. reemster HS2 / HSPRO 3 March 19th, 2009 01:51 PM
Event Conditions MRTaylor HS2 / HSPRO 3 October 21st, 2005 12:58 PM
