New Z-Wave toolbox
    #16
    You connect to the Z-Wave network from the interface not the physical toolbox.
    The updated user manual is Here. The new user manual is very helpful and has lots on information on Z-Wave in general.
    Look at page 38, Pairing the Toolbox with the Target Z-Wave Controller. This is done after the toolbox has paired with your Home Network.
    Once paired with your home network, check to be sure that you have the latest firmware. There was a fairly recent major update.
    You might also want to try different browsers. I think that I had issues with IE and found that Chrome worked better.
    I have had fantastic support from the Z-Wave Toolbox team! They also have a Facebook team that is helpful.
    DSteiNeuro
    HS3Pro
    MSI Cubi Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz, 2201 Mhz, 2 Core(s), 4 Logical Processor(s) 16GB DDRl RAM
    Enabled Plug-Ins
    BLRussound, BLSpeech, HSTouch Server, JowiHue, MyQ, Nest, Rain8, Squeezebox, Ultra1Wire3, UltraGCIR3, Vista Alarm, X10,Z-Wave
      #17
      Critical error has occurred! Please restart ToolBox and try again.
      Oops! Something went wrong....
      By the way, I have added it to Homeseer and it is connected: Successfully sent a frame to node 138 (Node 138 Z-Wave Static Controller) which was acknowledged.
      Elliott
      "Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
        #18
        Hi Elliot, I can't help with the tablet because I am currently using a PC browser.
        Is your tablet IOS or android? Either way, I would trying clearing the cache and also trying another tablet browser such as Goggle Chrome.
        If no luck, I am sure that the Toolbox support will contact you quickly. They were very helpful when I had an issue.
        David
        DSteiNeuro
        HS3Pro
        Enabled Plug-Ins
          #19
          David;
          Thanks for the positive feedback. I'm glad we were able to help you. We aim for quick and attentive answers regarding the ToolBox where ever we can. We've just revamped our phone and ticketing systems to be more responsive, which can be found on our ToolBox User's page. https://www.zwaveproducts.com/z-wave-toolbox
          Elliot;
          I hope you were able to figure everything out after our call. I thank you for your patience, as I'm still getting used to our new phone and ticketing systems. We're here if you need us. All the best.
            #20
            Originally posted by MDavisZWP View Post
            David;
            Elliot;
            Matthew:
            Thanks. Everything is fine. I second what has been stated above: I too have had fantastic support from the Z-Wave Toolbox team!
            Elliott
              #21
              Got a email promotional today in regards with "Z-Wave Toolbox" dropped price from $249 to $189. Mike
              Z-Wave Products carries the Z-Wave ToolBox, ZWP-TBX. Shop with us today.
              Computer: CUK Intel NUC7i7BNH
              Op System: Windows10 Pro - Work Station
              HS Version: HS4 Pro Edition 4.2.19.0
              Plug-Ins: AK Weather 4.0.5.25,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.7,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,Ring 1.0.0.9,SDJ-Health 3.1.1.3,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.32.0,Zigbee 4.0.11.0,Z-Wave 4.0.3.0, and Jon00 scripts.
                #22
                Originally posted by paul View Post
                Ok, decided to take the plunge and order one to my Austin office while I'm there next week for a conference (easier than shipping across the border). Guess I'll see how well it works!
                Hey Paul, what did you think of the z-wave toolbox?
                Plugin's:
                  #23
                  I love it! I have literally only spent probably a grand total of 30 minutes with the box since I bought it, but that's because I found my problem within 5 minutes of getting it working both times I've used it. My issue was that my entire z-wave network effectively got killed by interference and I couldn't find the source. I mainly used it for the signal graph that shows the full frequency spectrum, and when I spun it up I saw a huge bump right where the z-wave frequencies sit (the graph shows where the z-wave band is). Took it around the house until the band really grew huge, and tracked it down to the kid's baby monitor. The baby monitor has six channels, and one of those channels happens to be smack over the z-wave spectrum. A kid was playing with it and pushed the channel button enough times to hit that channel and left it there. It was cool - I started hitting the channel button on the monitor and watched the graph bounce around like a basket ball. So I chose the channel the farthest away from the z-wave band and like magic everything started working again.
                  The tool does way more than just this, but I simply didn't have need to use it's other features. I will say that the money was well spent for me in that with that single feature my network (which had been down for almost 2 weeks) was up and running again in minutes. I'd recommend it any day...
                  Paul
                    #24
                    Any chance we could see pics of the interface?
                      #25
                      Hello DSteiNeuro
                      Thanks for your purchase of the Z-Wave ToolBox.
                      Once you've joined the ToolBox with your tablet, go to your Homeseer controller and add a generic Z-Wave device, then immediately press the Learn button on the ToolBox.
                      With that being said, we've updated the ToolBox with a update, which addresses many customer requests. 1.3.0 is available for free and is an official update. In this case, you would add a generic Z-Wave device, then immediately press Connect to Network on the ToolBox. It's the same concept; just much faster and more stable.
                      When you succeed in your troubleshooting, we all succeed. Please feel free to contact us with any questions!
                      -Matthew
                      Matthew, are you looking to release this for other regions, AU, EU or if not is the toolbox configurable to use a different z-stick or UZB?
                        #26
                        Monk, what are you actually looking for? I've just received my unit yesterday and am exploring (trying to understand) the tool
                          #27
                          Maybe a screen grab of whatever you think is interesting - data it displays to you about your devices maybe.
                            #28
                            Tried to upload the user manual, but it exceeds the limit (even zipped 7Mb) Z-Wave Toolbox figures.docx
                              #29
                              Thanks - I'll find the manual online. Hopefully it shows examples of the data that is presented to the user. Curious what data is presented and how it looks on the screen.
                                #30
                                I attached a word document with screen captures... Now I've added apparently the new forum requires a two step process to upload and then insert within one's posting...
