I added cameras, they do not show up in HSTouch.
Discussions related to HomeSeer Beta 3.0.0.332->356
So far so good.
Only 2 plugins ZWXAVE and RFXCOM
I dont use HS touch
HS3 memory footprint climbed from 60ko to 85ko
All json behaviour is ok in my tests scripts
Jean
Current Date/Time: 01/07/2017 07:07:38
HomeSeer Version: HS3 Pro Edition 3.0.0.332
Operating System: Microsoft Windows 10 Pro Insider Preview - Work Station
System Uptime: 0 Days 0 Hours 11 Minutes 51 Seconds
IP Address: 192.168.1.78
Number of Devices: 129
Number of Events: 48
Available Threads: 400
Enabled Plug-Ins
30.0.0.35: RFXCOM
3.0.1.131: Z-Wave
Edit
After 3 hours run, memory footprint stablises at a steady 65ko
Current Date/Time: 01/07/2017 10:01:04
System Uptime: 0 Days 3 Hours 5 Minutes 17 Seconds
Enabled Plug-Ins
30.0.0.35: RFXCOM
3.0.1.131: Z-WaveLast edited by jmj09; July 1, 2017, 03:05 AM.
Guest
None of my device images are loaded anymore in HStouch. I see errors like this in my log:
jul-01 13:56:13 Warning Image file does not exist, returning blank image: \HomeSeer\html\/images/HomeSeer/status/on.gif
jul-01 13:56:13 Warning Image file does not exist, returning blank image: \HomeSeer\html\/images/HomeSeer/status/dim-50.gif
jul-01 13:56:13 Warning Image file does not exist, returning blank image: \HomeSeer\html\/images/HomeSeer/status/off.gif
It looks like it is using Windows paths for Linux?stefxx
Guest
Originally posted by stefxx View PostNone of my device images are loaded anymore in HStouch. I see errors like this in my log:
.332 is still working ok. HSTouch controls devices, but does not reflect the device's status. I've now tried it on several iOS devices, but not on Android or Windows. Cameras added on the new tab in setup, do not show on the clients.
EDIT: HSTouch default project doesn't work correctly on Android either. Can control devices, but the status of the device on HSTouch is not updated. No cameras.Last edited by randy; July 1, 2017, 01:58 PM.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Did the following:
1.Disabled and uninstalled HSTouch Server
2.Stopped HS3 service
3.wget the .332 version of HS3
4 tar the .332 version of HS3
5 Rebooted the system
All appears to operating normally with the exception of speaker host and a sign on/permissions issue and an updater issue as can be seen from below.
The one word that comes to mind with HSTouch is FAST.A massive speed improvement.Cameras are working fine with Netcam too. I'll leave it running for 24 hours and report back on status.
Jul-01 17:07:24 HSTouch Server Client iPad named iPad has DISCONNECTED.
Jul-01 17:07:24 HSTouch Server Client iPad:iPad (192.168.0.45/58837) has raised LineDisconnected.
Jul-01 17:07:24 HSTouch Server Warning Client dropped connection 192.168.0.45/58837
Jul-01 17:04:21 DEBUG Detected thermnumber was not previously saved, using index numbers
Jul-01 17:04:21 Speaker Speaker host disconnected, Name: IP address:
Jul-01 17:04:21 HSTouch Server Error, Unable to connect speaker client interface: Not Authorized
Jul-01 17:04:21 Warning Speaker host connection refused from 192.168.0.24 User: default User does not exist, does not have adequate rights, or the password is incorrect.
Jul-01 17:04:21 HSTouch Server Connecting speaker client to HomeSeer IP 192.168.0.24
Jul-01 17:04:21 HSTouch Server Client iPad (192.168.0.45/58837) named iPad has CONNECTED.
Jul-01 17:04:20 HSTouch Server Opening connection from:192.168.0.45/58837
Jul-01 17:03:34 HSTouch Server Client iPad named iPad has DISCONNECTED.
Jul-01 17:03:34 HSTouch Server Client iPad:iPad (192.168.0.45/58824) has raised LineDisconnected.
Jul-01 17:03:34 HSTouch Server Warning Client dropped connection 192.168.0.45/58824
Jul-01 17:00:51 DEBUG Detected thermnumber was not previously saved, using index numbers
Jul-01 17:00:51 Speaker Speaker host disconnected, Name: IP address:
Jul-01 17:00:51 HSTouch Server Error, Unable to connect speaker client interface: Not Authorized
Jul-01 17:00:51 Warning Speaker host connection refused from 192.168.0.24 User: default User does not exist, does not have adequate rights, or the password is incorrect.
Jul-01 17:00:51 HSTouch Server Connecting speaker client to HomeSeer IP 192.168.0.24
Jul-01 17:00:51 HSTouch Server Client iPad (192.168.0.45/58824) named iPad has CONNECTED.
Jul-01 17:00:50 HSTouch Server Opening connection from:192.168.0.45/58824
Jul-01 16:59:24 Updater An item in the Updater is temporarily unavailable due to getting response stream (ReadDone2): ReceiveFailure Item: http://automatedhomeonline.com/HomeS...traweatherbug3
System Setup
Current Date/Time: 01/07/2017 17:22:34
Linux version: Linux raspberrypi 4.4.21-v7+ #911 SMP Thu Sep 15 14:22:38 BST 2016 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 30 Minutes 14 Seconds
IP Address: 192.168.0.24
Number of Devices: 28
Number of Events: 3
Available Threads: 392
Enabled Plug-Ins
3.0.0.5: CM15A
3.1.13.8: CONCORD
3.0.0.14: NetCAM
24 hours later and all appears stable with .332. The only odd entry appearing in the log is the following
Jul-02 12:17:03 * DEBUG Detected thermnumber was not previously saved, using index numbers
I've definitely noticed an improvement in HSTouch with the integrated approach. Fingers crossed for this version.
Yesterday we noticed that none of our announcements through the Sonos plug-in were working. While I was met with great resistance when implementing voice announcements, missing them for a day was a big problem in the household. Rolling back to .318 cured it.
With HSTouch not reflecting status changes of devices and TTS not working, I'll have to stick with .318 for now.
I would be curious if anyone else has HSTouch dynamic status updates with v332.Last edited by randy; July 2, 2017, 10:39 AM.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
I am at a loss as to why your clients are not updating. I know you went back, but if possible, can you enable debug logging and post what happens when you update a device? I suspect maybe a plugin is interferring.
I tested it here and my clients update ok.
As for SONOS speaking, is this a sonos event? Do you know if it uses the speak proxy stuff?
Originally posted by rprade View PostYesterday we noticed that none of our announcements through the Sonos plug-in were working. While I was met with great resistance when implementing voice announcements, missing them for a day was a big problem in the household. Rolling back to .318 cured it.
Hi!
I just tested 3.33. The export and import of events seems to work now. Great! That will save me sooo much time in moving to Mono 4
However, the device images in HStouch still fail to load. The error changed a bit (but the path did not change for the better...):
jul-03 22:18:42 HSTouch Server Error in GetImage: Could not find a part of the path "/HomeSeer/\HomeSeer\html\/images/HomeSeer/status/off.gif".
jul-03 22:18:41 HSTouch Server Error in GetImage: Could not find a part of the path "/HomeSeer/\HomeSeer\html\/images/HomeSeer/status/on.gif".
"/HomeSeer/\HomeSeer\html\/images/HomeSeer/status/off.gif" should be "/HomeSeer/html/images/HomeSeer/status/off.gif"
Thanks!stefxx
In regards to the image error, is this on Windows or Linux?
Just updated to .333. Everything seems fine but connection to MyHS appears a little sluggish.Not as quick as .332.Any changes made that may cause this?
Current Date/Time: 03/07/2017 21:43:45
HomeSeer Version: HS3 Pro Edition 3.0.0.333
Linux version: Linux raspberrypi 4.4.21-v7+ #911 SMP Thu Sep 15 14:22:38 BST 2016 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 12 Minutes 5 Seconds
Number of Events: 3
Enabled Plug-Ins
3.0.0.5: CM15A
3.1.13.8: CONCORD
3.0.0.14: NetCAM
