errors in sonos pi
    errors in sonos pi
    I already posted this in the beta forum for Rich to take a look at but I thought I would see what you think. here is the log. I moved from .416 to .420 yesterday. I had to do the repair and replace my license.bin from a backup. sonos still is working by itself. I forgot to add...pi version .22
    Feb-20 11:37:00 AM Sonos Error Error in DoCheckAnnouncementQueue. 120 seconds expired since the announcement started and no end was received.
    Feb-20 11:35:57 AM Error reading file C:\Program Files (x86)\HomeSeer HS3\html\Sonos\Announcements\Ann_ALL_0.wav: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\html\Sonos\Announcements\Ann_ALL_0.wav' because it is being used by another process.
    Feb-20 11:35:57 AM Error In SpeakToFile: Exception from HRESULT: 0x80045012
    Feb-20 11:35:57 AM TTS Speak: ($SONOS$ALL$:*):The time is 11:35 AM
    Feb-20 11:35:55 AM Sonos Error Error in DoCheckAnnouncementQueue. 120 seconds expired since the announcement started and no end was received.
    Feb-20 11:35:54 AM Error reading file C:\Program Files (x86)\HomeSeer HS3\html\Sonos\Announcements\Ann_all_2.wav: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\html\Sonos\Announcements\Ann_all_2.wav' because it is being used by another process.
    Feb-20 11:35:54 AM Error In SpeakToFile: Exception from HRESULT: 0x80045012
    Feb-20 11:35:53 AM Sonos Error Error in DoCheckAnnouncementQueue. 120 seconds expired since the announcement started and no end was received.
    Feb-20 11:35:53 AM Error reading file C:\Program Files (x86)\HomeSeer HS3\html\Sonos\Announcements\Ann_all_1.wav: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\html\Sonos\Announcements\Ann_all_1.wav' because it is being used by another process.
    Feb-20 11:35:53 AM Error In SpeakToFile: Exception from HRESULT: 0x80045012
    Feb-20 11:35:52 AM Sonos Error Error in DoCheckAnnouncementQueue. 120 seconds expired since the announcement started and no end was received.
    Your problem is here:
    Is this a Linux of Windows install? I think in Windows it is all part of the OS but in Linux you need flite and Speak_to_file.sh needs to be set right.
    If Windows, is the PI running with admin rights, because it must!
    Dirk
