GoControl Irrigation setup?
I test it and it work. I don't have other parameter. You can contact
security.linear@nortek.com
and ask your question. They were very helpfull
Below is my email to support and their answer. It appears to be the way HS sees the irrigation controller, not the configuration of the controller itself. I also have an Aeotec controller but it would still be through HS3 software.
The problem is that if I trigger an event that has valve 1 for 10 minuts, then valve 2 for ten minutes, etc and I want to stop the event, I can't. It seems the combination of "Irrigation System Enable" and/or "Irrigation Notification" should be able to stop the system.
Originally posted by troy.lynch View PostI just ordered one of these and want to control the valves to and on off state without a timer. Is this possible?
Originally posted by cowinger View PostI am not sure what you mean by a timer but the valves can be set in an event to any time you wish by using an on, wait, off commands. This bypasses the drop down. Is that what you are asking?
Here is an example of one of my events. It shows a few valves. The event was too long to show all. I can show the last part if you want. The controller power cycle is an appliance module that turns power on to the controller. Just for my purposes. The wait allows it to be on for the time selected and then you turn the valve off.
I see. I was looking for just a on or a off on the valve. I'm not actually using this for irrigation. I'm using it to fill aquariums with relay and tubes running to the tanks and then have water sensors at the tanks which I want to trigger the valves. I think I can figure out a way for this to work. I just was looking for more of an on off type thing.
Originally posted by troy.lynch View PostI see. I was looking for just a on or a off on the valve. I'm not actually using this for irrigation. I'm using it to fill aquariums with relay and tubes running to the tanks and then have water sensors at the tanks which I want to trigger the valves. I think I can figure out a way for this to work. I just was looking for more of an on off type thing.
Having a timed open value would be a good overflow fail safe if the high level water sensor trigger did not work for some reason.Len
Linux version: Linux homeseer Ubuntu 16.04 x86_64
Number of Devices: 633
Number of Events: 773
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
3.0.0.48: EasyTrigger
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.0.87: weatherXML
3.0.1.190: Z-Wave
