Wondering if anyone knows what is the millimeter size of the power jack on the way2call usb units? Looking to buy a +12 power adapter off of amazon or ebay but need to know what the connector size should be on the power adapter. I am sure it is a standard millimeter size plug, just not sure what it is? Thanks much !!!! Rick
Way2Call Power Adapter Plug Size
Thinking it is a standard 2.5mm barrel connector. Here just made up two new power cables for two W2C boxes with a connection to the Leviton media can 12VDC power supply and used some 12 VDC wires with 2.5mm barrel connectors. They are working fine.
Both are connected to same power supply but each one is fused. All Electronics has 2.5mm and 2.1mm barrel connectors with leads.
2.5MM COAX PLUG ON 4" CABLE
[ATTACH]63388[/ATTACH]
All Electronics also has regulated low amperage 12VDC power supplies with same barrel connector. (2.5mm).
12 VDC 1 AMP POWER SUPPLY
[ATTACH]63387[/ATTACH]Last edited by Pete; September 17, 2017, 06:38 AM.- Pete
Thanks Pete,
Is the connector that plugs into way2call units 2.5 mm? You had also mentioned 2.1 mm in your post? Should be able to find a power adapter (12 Volt) on ebay or amazon with a 2.5 millimeter connector. Just need to know if it is actually 2.5 mm and not 2.1 mm that plugs into power connector on way2call unit. Thanks again for all your help !!!! Rick
