I was wondering if anyone else has seen the problem I am having with the external temperature update function of the HAI Thermo plugin.
I have an RC80B and have perfect comms with it. This can be seen in the logs as the house temperature change so the logs reflect that change either up or down. When I remote control the unit it also works fine.
My problem is with the external temperature function. In the plugin I have setup my weather station external temperature sensor as the device to provide external temperature updates on the thermostat.
At first after restarting homeseer everything works fine and the thermostat does display the correct external temperature. This goes on for a few hours and then all of a sudden the unit seems to no longer change the temperature being displayed. It still toggles the diplay between internal and external tempertaure except the external temperature no longer changes.
I have confirmed that the weather station external temperature device value in homeseer is changing in accordance with the weather station so see no problem here.
Again another restart of homeseer see this working again.
Any ideas here?
Cheers
Nick
Any ideas here?
Cheers
Nick
