I'm new to Homeseer, but I've had my CPUXA and SECU16 for some time with ECS, which I'm abandoning for Homeseer.
The Ocelot (CPUXA) works fine with X10, and the SECU16 devices were created when I added the plugin as a IO device. The problem is that the analog values aren't showing up in Homeseer. I have configured them as analog (they originally said digital after the plugin added them) and the value simply reads as 0. I checked CMAX and the current value for the I/0 input I'm testing reads 112. Not so in Homeseer. I've tried both the Homeseer plugin and now ADIOcelot (which is much more flexible, by the way!)
Do I need to be running CMAX 2.0 and the corresponding executive in the Ocelot? I'm current running 1.70 but I could upgrade.
I've seen posts that talk about copying the I/O value to a CMAX variable, but since the device is there, what's the point of this? I may give it a shot anyway.
Any help in getting analog values that read correctly and update is appreciated.
