I am trying to create an HS Event that could transfer a skype (video) call that is currently in progress, so that the original caller and the new party could continue the conversation.
I am using "Place Skype Call" as the event action type... along with the "transfer to" party's Skype ID, and using the "skype_Transfer.vb script" with nothing in the "parameter" value.
Nothing happens....with the Log showing the following error...
7/27/2008 1:48:27 PM - Skype Debug - SkypeResponseEvent - #53 ERROR 99 CALL: A call exists in INPROGRESS state
This may or may not be relevant but I also have an error at the start of the call.... which may have some bearing on trying to do the transfer...
I am using the (default) incoming_vb script to take the initial call and notice that it too, throws and error when the call starts... although everything seems to work otherwise (ie- the call gets through).... the initial error shows this description:
7/27/2008 1:47:12 PM - Error 2 - Cannot run script skype_incoming.vb, entry point function not found: CallConnected
Any Help Would be appreciated!
-Bob
-Bob
