I have followed the steps in configuring remote RaspberryIO between a RPi 3 and a Windows HS3 system using RaspberryIO ver 3.0.0.12. The plugin on RPi shows connection to the HS3 system and the INFO lines. The Windows HS3 system shows the plugin connected, and if I disconnect on the RPi, I see it disconnect on HS3, then reconnect when I run it on the RPi again. I rebooted the RPi a few times and ran apt-get update/upgrade once more for good measure then rebooted again.
I'm NOT seeing the Remote Plugin on the Manage Plug-Ins screen, and under Plug-ins | RaspberryIO, I see Config, User Guide, and Forum, but no instance-specific option. Instance name is set in the RPi config file per your instructions.
I've set Log Level to debug on the RaspberryIO Plug-in on HS3, and see the plugin RaspberryIO has connected and I see "IP:<shows correct RPi IP>:53874", and the same INFO lines I see in the console of the RPi. I also see a log entry when I start the RaspberryIO plug-in on the Windows system that says "ERROR System is not a Raspberry Pi" before all the non-error connection log entries for the RPi, but I presume that is just saying you can't run RaspberryIO plugin natively on the Windows PC since it's not the expected platform/architecture.
My systems have all the outward signs of the two talking to each other, except for the Remote Plug-in is missing from the Manage Plug-ins, and there is no instance-specific configuration screen under the Plugin config menu.
I installed the RPi Debian from scratch yesterday, and all apt-get updates/upgrades are applied. The platform is a RasPi 3 Model B, Debian 9.4, and Mono 4.6.2 (with all mono parts you describe in your upgrade to 4.x post). On both the RPi and Windows 10 1709 with HS3 3.0.0.368, I've got RaspberryIO plug-in ver 3.0.0.12.
Does this sound like a familiar issue? What am I doing wrong?
