Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeTroller Zee
HomeTroller Zee Discussions related to the HomeTroller Zee automation controller based on Linux.
Old October 1st, 2017, 06:24 AM
scg scg is offline
Seer Deluxe
Lost all devices!!!
I had a power outage and lost all my devices. Tried a recent restore and the an old restore...Nothing. This is the second time. The first was with the new update 375. I'm now back to HS3 ZEE S2 Edition 3.0.0.368 (Linux).
Matt with support helped me the first time but I can't find the email to recreate the reinstall or repair.
I would appreciate any help. I contacted support but have not heard back.
Thanks!!!!
Old October 1st, 2017, 07:02 AM
Pete's Avatar
Pete Pete is online now
OverSeer
All of your Z-Wave nodes reside in the Z-Wave hardware device.
If you delete or rename the /HomeSeer/Data/Z-Wave/Z-Wave2.db it will recreate itself.
Note this is only the nodes and not the events and triggers.
The events and triggers are stored in the Homeseer database.
If you have lost these then you can go to a back up of the Homeseer Database which is located at /HomeSeer/Data
main database is called: HomeSeerData.hsd
Backups are called: HomeSeerData_1.hsd to HomeSeerData_10.hsd
Do a baby steps thing. Make sure you have shut down Homeseer and backed up the Homeseer directory before you do this.
1 - shut down Homeseer
2 - back up Homeseer directory
3 - delete Z-Wave database
4 - copy old Homeseer database base to HomeSeerData.hsd
5 - reboot or restart Homeseer 3.
If all concern only relates to Z-Wave nodes all you need to do are steps 1,2,3 and 5. (skip 4).
Automator
HS3 Pro & Lite Edition Beta 3.0.0.4449
Old October 1st, 2017, 08:36 AM
scg scg is offline
Seer Deluxe
Question
Hi Peter,
I have no HS3 directory. I search all of C: drive and in Windows directory.
Old October 1st, 2017, 08:43 AM
Pete's Avatar
OverSeer
It is there.
Are you running Windows 10 64 bit or Windows in 64 bit mode?
In a Windows 64 bit computer Homeseer 3 resides in the C:\Program Files (x86) directory.
In a Windows 32 bit computer Homeseer 3 resides in the C:\Program Files directory.
Make sure you back up the entire Homeseer Directory with Homeseer in off mode before making any changes.
Always back up your Homeseer 3 directory before making any changes. It takes 5 minutes to restore a backup.
First time I am reading about a V.375. I am still on V.368 on two Homeseer boxes here (running Linux)
Old October 1st, 2017, 08:59 AM
scg scg is offline
Seer Deluxe
I'm running Windows 64 bit computer Homeseer 3 is not in the C:\Program Files (x86) directory.
Old October 1st, 2017, 09:04 AM
scg scg is offline
Seer Deluxe
I may have the v.375 wrong. It was the latest update
Old October 1st, 2017, 09:29 AM
Pete's Avatar
OverSeer
Thinking latest update is V.368.
Look at the Homeseer 3 icon on your desktop. Right click properties. Properties will show where it is installed.
You probably need to utilize administrative rights to see the directory.
Go slow, baby steps you will find the Homeseer 3 directory.
Have a read here relating to default install directories ..
Which Win OS should I choose for my new PC
Old October 1st, 2017, 10:19 AM
scg scg is offline
Seer Deluxe
Peter no HS3 on desktop or in programs, windows, program x86. Nowhere to be found. Show hidden files is checked. I just tried restore interface. It did nothing.
Oct-01 10:17:13 AM Z-Wave Warning A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed.
Oct-01 10:15:00 AM Log Info The log database is currently 0.11MB in size.
Oct-01 10:14:30 AM Z-Wave Main Homeseer is a SUC or SIS for this network.
Oct-01 10:14:30 AM Z-Wave Main Homeseer Controller is static lib.
Oct-01 10:14:30 AM Z-Wave Main Homeseer Controller chip type is ZW050x.
Oct-01 10:14:30 AM Z-Wave The interface's security support has been set.
Oct-01 10:14:30 AM Z-Wave Main Homeseer: Found 11 Z-Wave nodes in interface node ID 1 (Main Homeseer)
Oct-01 10:14:30 AM Z-Wave Main Homeseer: Z-Wave interface node ID: 1, Home ID: D490CCC0
Oct-01 10:14:30 AM Z-Wave Main Homeseer: Z-Wave Serial API version: 5
Oct-01 10:14:29 AM Z-Wave Main Homeseer: Controller firmware version: 4.32
Oct-01 10:14:29 AM Z-Wave Main Homeseer: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
Oct-01 10:14:27 AM Z-Wave Main Homeseer: Getting node information from controller...
Oct-01 10:14:27 AM Z-Wave Main Homeseer: ----------------------------------------------------------------------
Oct-01 10:14:27 AM Z-Wave Initializing Z-Wave interface Main Homeseer (HomeSeer Z-Troller) on /dev/ttyAMA0
Oct-01 10:14:27 AM Z-Wave Main Homeseer: ============================================================ ==========
Oct-01 10:14:27 AM Z-Wave Main Homeseer: Exiting COM Device Thread
Oct-01 10:14:26 AM Z-Wave Main Homeseer: Restore of node information COMPLETE.
Oct-01 10:14:26 AM Z-Wave Main Homeseer: Controller firmware version: 4.32
Oct-01 10:14:26 AM Z-Wave Main Homeseer: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
Oct-01 10:14:21 AM Z-Wave Warning A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed.
Oct-01 10:14:21 AM Z-Wave Main Homeseer: Node information has been successfully loaded - restarting the controller...
Oct-01 10:14:17 AM Z-Wave Main Homeseer: Restoring node information for node 35...
Oct-01 10:14:17 AM Z-Wave Main Homeseer: Restoring node information for node 34...
Oct-01 10:14:17 AM Z-Wave Main Homeseer: Restoring node information for node 32...
Oct-01 10:14:16 AM Z-Wave Main Homeseer: Restoring node information for node 31...
Oct-01 10:14:16 AM Z-Wave Main Homeseer: Restoring node information for node 28...
Oct-01 10:14:16 AM Z-Wave Main Homeseer: Restoring node information for node 25...
Oct-01 10:14:16 AM Z-Wave Main Homeseer: Restoring node information for node 13...
Oct-01 10:14:16 AM Z-Wave Main Homeseer: Restoring node information for node 12...
Oct-01 10:14:16 AM Z-Wave Main Homeseer: Restoring node information for node 11...
Oct-01 10:14:16 AM Z-Wave Main Homeseer: Restoring node information for node 7...
Oct-01 10:14:16 AM Z-Wave Main Homeseer: Restoring node information for node 1...
Oct-01 10:14:13 AM Z-Wave Main Homeseer has successfully been made the SIS for this network.
Oct-01 10:14:13 AM Z-Wave Main Homeseer attempting to set as SUC/SIS...
Oct-01 10:14:13 AM Z-Wave Main Homeseer is the Primary Controller for this network.
Oct-01 10:14:13 AM Z-Wave Main Homeseer Controller is static lib.
Oct-01 10:14:13 AM Z-Wave Main Homeseer Controller chip type is ZW050x.
Oct-01 10:14:13 AM Z-Wave The interface's security support has been set.
Oct-01 10:14:12 AM Z-Wave Main Homeseer: Found 1 Z-Wave nodes in interface node ID 1 (Main Homeseer)
Oct-01 10:14:12 AM Z-Wave Main Homeseer: Z-Wave interface node ID: 1, Home ID: D490CCC0
Oct-01 10:14:12 AM Z-Wave Main Homeseer: Z-Wave Serial API version: 5
Oct-01 10:14:12 AM Z-Wave Main Homeseer: Controller firmware version: 4.32
Oct-01 10:14:12 AM Z-Wave Main Homeseer: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
Oct-01 10:14:12 AM Z-Wave Main Homeseer: Getting node information from controller...
Oct-01 10:14:06 AM Z-Wave Warning A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed.
Oct-01 10:14:01 AM Z-Wave Main Homeseer: Erase complete - sending the network ID to the interface.
Oct-01 10:14:01 AM Z-Wave Main Homeseer: Controller firmware version: 4.32
Oct-01 10:14:01 AM Z-Wave Main Homeseer: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
Oct-01 10:13:59 AM Z-Wave Z-Wave Interface Main Homeseer (1) has been reset to its defaults.
Oct-01 10:13:59 AM Z-Wave Warning Main Homeseer: Erasing the interface...
Old October 1st, 2017, 10:37 AM
Pete's Avatar
OverSeer
Homeseer 3 has to be starting from some directory on your computer and when it was installed by default it drops a Homeseer 3 icon on your desktop.
How do you auto start Homeseer 3 when the computer reboots?
Actually erasing the configuration on your ZTroller does more harm than good. The read of the Z-Troller is what you want to do.
The above is reading your firmware and ZWave database.
The below stuff is a proactive deletion of the nodes that are stored in your ZTroller.
That message above relating to erasing your interface will be deleting all of your ZWave nodes and unless you have a backup you will need to reconfigure or pair each node to your controller which will be a PITA.
The firmware in your Z-Wave controller stores all of your Z-Wave nodes.
The Homeseer ZWave database is a copy of these from the ZWave firmware on your ZTroller.
Old October 1st, 2017, 10:51 AM
scg scg is offline
Seer Deluxe
Well I guess I'll wait for support to reply. I may have to reinstall all devices. Then I think I'll look for a new hub. It seems I keep fixing things with HS. Nothing stays constant. May I'll try the new echo plus. And if it works better then HS I'll put my Z on eBay.
That being said, I'd Like to thank you for trying to help me. It's much appreciated.
Art
Old October 1st, 2017, 11:08 AM
Pete's Avatar
OverSeer
@Art,
I would have a look at the ZNet.
I never touch mine as it is POE connected in the attic of my home.
I also have the ZTroller, ZWave USB sticks. These are no longer used anymore.
Don't get frustrated.
The Echo is just a voice activated console. It needs to talk to some sort of cloud connected at home hub to work. Here also use the Amazon Echo.
I also have been tinkering with the Samsung Smartthings hub. While it works fine it is no comparison to Homeseer.
Old October 1st, 2017, 11:32 AM
scg scg is offline
Seer Deluxe
The new echo plus has it's own hub built in.
It handles z wave , z wave plus and zigbee.
From what amazon support tells me it will just discover your devices. And it can be programed just like events. I now use alexa with HS and IFTTT. I think with the new echo there's no need for IFTTT. And I won't need a another hub, we'll see. I just ordered one. It shis 10/31
Old October 1st, 2017, 11:45 AM
scg scg is offline
Seer Deluxe
The ZNet replaced the zee2?
Old October 1st, 2017, 12:15 PM
Pete's Avatar
OverSeer
Understood Art.
I do Zigbee here today. Started goofing around with the Almond + a few years back.
It is in the Samsung Hub and I have a ZIM (Zigbee Interface) connected to my Leviton Omni Pro 2 security panel.
I guess I am sticking mostly to Homeseer because it resides in my home and I am not really a cloud person (even though I tinker with this stuff).
The ZNet device is an ethernet based Z-Wave controller. This allows you to put the Z-Wave controller any place in your home and separate from your main Homeseer 3 controller.
The Zee2 is a Raspberry Pi based Homeseer 3 box. The original Zee was the first of it's kind. It is the mini version of Homeseer 3. I call it Homeseer lite. It only runs on Linux today.
HTML code is Off
Lost ALL Devices.... chadg Insteon Plug-in (Mark Sandler) 42 October 19th, 2017 11:24 AM
Devices lost emabonacchi xAP Discussions 1 June 19th, 2012 01:27 PM
Help! Lost all of my devices djc1603 RFXCOM Plug-In (3P) 1 March 27th, 2009 07:17 AM
lost devices?? Rotech jvESS Plug-In 2 February 18th, 2009 07:04 PM
Tap-Add... lost all other devices jlegan Insteon Plug-in (Mark Sandler) 0 February 5th, 2006 01:52 PM
