I had been noticing a small number of homeseer failed to trigger zwave device errors in the log. They affected various devices with no obvious consistency and on occasions homeseer would hang and no devices would work, this was resolved by either replacing the zstick or restarting homeseer. This morning I decided to upgrade the firmware on the zstick to see if that helps. Everything seemed ok and then after 4 hours a bunch of devices stopped and stubbornly refuse to reconnect unless they are moved nearer to the zstick. I now have zwave Bermuda Triangle. I am now trying to decide if I update to a newer gen 5 zwave plus stick (I have a s2), go to a znet device and if I do that can I continue to use the s2. Are there any recommendations or suggestions as to how to improve things and how easy is it to migrate?
Steve
Steve
