Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeTroller Zee
HomeTroller Zee Discussions related to the HomeTroller Zee automation controller based on Linux.
Old July 20th, 2017, 02:57 PM
Otto-mation Otto-mation is offline
Seer Plus
Hometroller plugin for Canadian weather?
Hi folks, can anyone recommend a Canadian weather plugin for the Hometroller Zee?
I would be giddy if I could tie events to weather notices etc.
Steve
-steve
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.368
Linux version: Linux HomeTrollerZeeS2 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux System Uptime: 1 Day 15 Hours 31 Minutes 5 Seconds
Number of Devices: 329
Number of Events: 180
Available Threads: 399
Enabled Plug-Ins
3.0.0.5: CM15A
3.0.0.42: EasyTrigger
3.0.0.17: EnvCan
3.0.1.130: Z-Wave
Old July 20th, 2017, 04:23 PM
freeon freeon is offline
https://forums.homeseer.com/showthre...iroment+canada
This what I use.
Old July 20th, 2017, 07:05 PM
Seer Plus
Thanks Freeon - is there any documentation available somewhere?
I found some steps that said to copy it to my Homeseer folder, which I did, and then the plugin appeared in my list. But after doing a restart, I still didn't see any new devices.
Did I miss some steps?
Old July 20th, 2017, 07:57 PM
Did you go into plugin/envcan/feeds and configured it?
Old July 20th, 2017, 08:12 PM
Seer Plus
I did. Don't know if I created the entry correctly.
I used
https://weather.gc.ca/rss/city/on-54_e.xml
as the Atom feed entry and then enabled it and don't know what's next.
My log file shows
Jul-20 8:06:37 PM envcan error in feed: https://weather.gc.ca/rss/city/on-54_e.xml - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure[/I][/I]
Are there any sample screenshots available anywhere that might help?
Am I close?
Thanks in advance
Old July 20th, 2017, 08:20 PM
Here is a screenshot of mine. I installed it 3 years ago and haven't touched since. I don't remember all the steps I did to get it to work.
Old July 20th, 2017, 08:51 PM
Seer Plus
And then the device(s) just showed up?
Rats - feel like I'm so close.
I tried using Toronto for a mainstream one.
Going to add Moncton since we know that works, because you're using it.
I appreciate the screenshot - helps me know I'm close.....I think.
Old July 20th, 2017, 09:18 PM
Seer Plus
Progress!
I entered the Moncton feed and it worked!
So the Toronto and Pickering ones weren't working.
That made me look at the version I had since there were some other posts here about feed errors that had been fixed and noticed that I was using an old version.
I just deleted it and installed 3.0.0.17 (think I had 3.0.0.4)
Fingers crossed while it reboots.
Ahhh! This version has sample feeds already in there - fabulous help!
Getting closer!
Old July 20th, 2017, 09:26 PM
Yes from what I remember all the devices just showed up.
Old July 21st, 2017, 09:16 AM
Seer Plus
Not all feeds working with EnvCan plugin
Unfortunately, only the Moncton one worked for me but is of no use to me.
For Toronto, Pickering and Montreal, my log says
Jul-21 9:02:19 AM envcan error in feed: https://meteo.gc.ca/rss/city/qc-147_f.xml - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
Jul-21 9:01:16 AM envcan error in feed: https://weather.gc.ca/rss/city/on-143_e.xml - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
Jul-21 8:56:49 AM envcan error in feed: https://weather.gc.ca/rss/city/on-54_e.xml - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
Jul-21 8:56:00 AM envcan error in feed: https://weather.gc.ca/rss/city/ab-52_e.xml - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
Just tried Oshawa too but same error.
Seems like I'm teasingly close but out of ideas.
If anyone has suggestions, I'm all ears
Old July 21st, 2017, 12:20 PM
sparkman's Avatar
sparkman sparkman is offline
I would post in the thread for the plugin, so that there's a better chance that the author of the plugin sees your posts. FWIW, I just tried some of the feeds that aren't working for you and they do work for me. You may want to try the non-ssl link instead (ie. http://weather.gc.ca/rss/city/on-54_e.xml instead of https://weather.gc.ca/rss/city/on-54_e.xml).
Cheers
Al
Old July 21st, 2017, 12:35 PM
Seer Plus
Cheers
Al
SCORE!!!
That did the trick!
As soon as I changed the URL to HTTP, it worked!
Helluva great way to start the weekend!
Much thanks, Al! (and Freeon)
Old July 21st, 2017, 12:42 PM
sparkman's Avatar
SCORE!!!
That did the trick!
Great, glad that worked for you!
Cheers
Al
Old August 22nd, 2017, 03:51 PM
Seer Plus
Cheers
Al
HI Al, This may be a stupid question but which forum would that be? I don't seem to see a forum specifically for the EnvCan weather feed. Can you suggest the best place as I have more questions for the developer.
Old August 22nd, 2017, 04:23 PM
I don't that there is a forum section for it. Just this post.
Old August 22nd, 2017, 04:58 PM
Seer Plus
OK, thanks - I will post my question from there.
Cheers!
Tags
canadian, hometroller, plugin weather, weather
Canadian Weather Plugin karls Script & Plug-In Library Discussion 40 December 7th, 2010 09:04 PM
Canadian Weather The Ol Alfer Script & Plug-In Library Discussion 16 February 28th, 2008 10:58 PM
Canadian Weather Plugin karls Script & Plug-In Library 0 February 28th, 2008 09:40 PM
Canadian Weather Script karls Script & Plug-In Library 0 October 12th, 2005 09:51 PM
Canadian Weather Script paulrimmer Script & Plug-In Library Archive 3 January 28th, 2002 11:17 PM
