Just started working with the plugin and before I get to far, I want to make sure I'm not missing something.
I have applied each output of the GC100 to a room where there is a xantech ir distribution to multiple devices in each room. So each room, has a directv receiver, meaning each output on the GC100 which corresponds to an IR device in the plugin.
I am using the hex codes for the directv remote buttons and manually entering them into the IR device in the plugin after converting them with the GC iconvert program.
PROBLEM: Once I enter all the directv buttons for one GC plugin device, do I have to re-enter them for another GC plugin device if I want to control another directv receiver in a different room which is associated with a different GC device? So if I have five directv receivers do I have to enter all the directv buttons (codes) 5 different times? Once for each zone (GC IR device).
Is there a central repository for codes and then you assign them to GC IR devices, or and easy way to copy codes between devices?
Thanks (sorry for the length)
