Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Ultra Scripts and Plug-Ins > UltraGCIR HSPI
UltraGCIR HSPI Discussion area for the UltraGCIR HSPI plugin.
Old November 23rd, 2012, 06:00 PM
Club Chapin Club Chapin is offline
Seer Deluxe
GC-100 Status
I've got a GC-100 set up. I've been starting to dork with GCIR plug in. Pretty cool. Have my TIVO IR remote controlling my zwave and sonos.
I've got the correct GC-100 IR/Sensor ports set to :"Sensor_with Autonotify".
Whether sensor is open or closed, it is reported "Inactive"
If the 1/8" is unplugged from the GC-100, It is reported as "Active"
I presume that this is not correct behavior.
It seems that the status reflects the connectivity of the plug, not the state of the plug.
An open plug reports differently than a disconnected port.
Does the GC-100 require a plug other than a 1/8" 2 pole?
I think that I am running current software and firmware.
Thanks, Pete
Old November 23rd, 2012, 09:38 PM
Ultrajones's Avatar
Ultrajones Ultrajones is offline
OverSeer
I just tested the sensor with auto-notify with a Global Cache GC-SP1 and it is working. Are you using a Global Cache sensor or are you trying to create your own?
Regards,
Ultrajones
Old November 25th, 2012, 04:33 PM
Seer Deluxe
I'm creating my own, using a garage door receiver and a zwave dry contact. At this point, it is not working by simply shorting an 1/8" plug's contacts together.
I don't think this is actually a plug in issue, but a GC-100 issue. I thought maybe someone here has seen this and might know how to remedy it.
I've opened a ticket with GC, hopefully they will respond in the next day or so.
Pete
Old November 25th, 2012, 05:54 PM
Ultrajones's Avatar
OverSeer
You may need to buy one of these:
http://store.homeseer.com/store/Glob...r-P864C47.aspx
Regards,
Ultrajones
Old November 25th, 2012, 10:20 PM
Seer Deluxe
Thanks. This must be it. I expect GC will say the same thing.
Do the itach devices require this?
Pete
Old November 25th, 2012, 10:47 PM
Seer Deluxe
Looking this up on the GC site, led me to this doc:
http://www.globalcache.com/files/doc...C1_distrib.pdf
Which indicates the pinout with a TRS, not a TS, with Ring and Sleeve as the closure, not Tip and sleeve.
I wired a TRS this way and now this works.
I am now controlling my lighting with my car garage door opener (I have a carport with no garage door) using a WDRR-372R: http://www.waynedaltonstore.com/prod...ersion-module/
Thanks for steering me in the right direction.
Pete
HTML code is On
