I have a KPL button that does nothing but arm my house in night mode. It is connected only to the PLC so that it can trigger the night arming event, and I have verified this with both HS and Powerhome (which I don't keep running, but use only for some linking). The problem is that it is also turning on a particular light as well, but a link to this light (or any light) does not show up in HS or PH. I have deleted the apparent link to the light manually several times, and that works for a day or so, then it reappears. I have also tried adding a link to the light (which then DOES show up in HS and PH) and then deleting it, with the same result -- it disappears, then reappears.
Does anyone have any idea what is going on here? It's just this one light and KPL button combo...
Joe
Joe
