Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Ultra Scripts and Plug-Ins > UltraGCIR HSPI
UltraGCIR HSPI Discussion area for the UltraGCIR HSPI plugin.
Old October 5th, 2013, 09:34 AM
Ultrajones's Avatar
Ultrajones Ultrajones is offline
UltraGCIR3 HSPI - Bug Reports
Please post any issues you experience with the UltraGCIR3 HSPI here.
Old October 5th, 2013, 10:25 AM
vasrc's Avatar
vasrc vasrc is offline
Here you go.
1. Options->Wait time: Saves changes to ini file correctly, but always shows 1.
2. Actions don't seem to be working yet?
One minor comment.. When you first startup the plugin it looks for all of the GC devices and then creates HS devices for them (not exactly sure when that occurred though). When you put in the IP's to ignore, it's after the fact (or so it seems) and they are already created so you need to manually delete them. Not a huge deal, and I suspect putting logic to stop it from auto-creating the devices would probably be ugly..
Z
Old October 5th, 2013, 02:06 PM
rhodesep rhodesep is offline
Double entries
UJ
Not sure if this is the plugin or HS3. Appears to be in your plugins, sometime double entries and there are a couple of triple entries.
Gene
Old October 5th, 2013, 03:02 PM
Ultrajones's Avatar
I think that is HomeSeer3. I have seen that when viewing View > Device Management, but a refresh fixes it. Do you see that every time?
Ultrajones
Old October 5th, 2013, 07:51 PM
It's there all the time. When adding an event I have to search through however many there are to fine the one that works. If there are three there only one will be the one that works. The other two will not work. Bye the way I do not see them when I view device management.
Old October 10th, 2013, 12:35 PM
NicolaiL's Avatar
NicolaiL NicolaiL is offline
Super Seer
Hi
The plug-in installs fine for me, but I can't get it to detect my iTach devices (3 IR and 1 Serial).
I am running HS3 on Windows 8 Pro and have added incoming firewall exceptions for UDP on port 9131 and TCP on 4998-5001 but this has not helped.
Any ideas?
Nicolai
Old October 10th, 2013, 01:10 PM
jowens14
Guest
Posts: n/a
Originally Posted by NicolaiL View Post
Hi
Any ideas?
Nicolai
Same problem here, but on Windows 7.
I turned off the firewall, still no contact.
Jeff
Old October 10th, 2013, 01:14 PM
vasrc's Avatar
All of my Itach's (even the new flex) are being found on Windows 7 with no modifications to the firewall.
I actually have to put some of them in the ignore box (Ztrollers) so it doesn't grab them.
Z
Old October 10th, 2013, 06:03 PM
Ultrajones's Avatar
If you're having issues getting the plug-in to recognize your devices, then please confirm they can be seen by the Global Cache iHelp program.
Ultrajones
Old October 11th, 2013, 03:16 AM
NicolaiL's Avatar
Super Seer
Ultrajones
Hi Ultra,
Confirmed iHelp on the same box finds all my iTachs.
Regards
Nicolai
Old October 11th, 2013, 12:43 PM
jowens14
Guest
Posts: n/a
Ultrajones
All of mine are found. Also your plugin for HS2 on the same box finds them all.
I have debug logging turned, but don't get any log messages beyond that the plugin initialized.
(HS2 & HS3 are not running at the same time)
Old October 11th, 2013, 03:36 PM
vasrc's Avatar
I notice that since the latest HS3 update (3.0.0.34?), on startup I now get in the log:
10/10/2013 7:23:13 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '1' Key being added: '1'
10/10/2013 7:23:13 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '0' Key being added: '0'
10/10/2013 7:23:13 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-1' Key being added: '-1'
10/10/2013 7:23:13 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-2' Key being added: '-2'
10/10/2013 7:23:13 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-3' Key being added: '-3'
10/10/2013 7:23:12 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '1' Key being added: '1'
10/10/2013 7:23:12 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '0' Key being added: '0'
10/10/2013 7:23:12 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-1' Key being added: '-1'
10/10/2013 7:23:12 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-2' Key being added: '-2'
10/10/2013 7:23:12 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-3' Key being added: '-3'
10/10/2013 7:23:07 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '1' Key being added: '1'
10/10/2013 7:23:07 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '0' Key being added: '0'
10/10/2013 7:23:07 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-1' Key being added: '-1'
10/10/2013 7:23:07 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-2' Key being added: '-2'
10/10/2013 7:23:07 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-3' Key being added: '-3'
Old October 11th, 2013, 04:15 PM
Ultrajones's Avatar
Can you enable debug, then restart the plug-in in developer mode, then send the console output to ultrajones@hotmail.com?
Ultrajones
Old October 11th, 2013, 04:56 PM
NicolaiL's Avatar
Super Seer
Ultrajones
Sent
Old October 11th, 2013, 05:51 PM
Ultrajones's Avatar
If you're experiencing an issue getting the plug-in to recognize your Global Cache devices, please try this and report back:
1) Open up hspi_ultragcir3.exe.config in the HomeSeer3 root directory using notepad
2) Change the line
PHP Code:
<probing privatePath="bin\hspi_ultracid3"/> to <probing privatePath="bin\hspi_ultragcir3"/>
3) Save the file
4) Restart HomeSeer
If that fixes it, I’ll update the package and publish the fix.
Ultrajones
Old October 12th, 2013, 07:09 AM
lhfarm lhfarm is offline
That change worked for me.
Barry
Old October 12th, 2013, 09:39 AM
Ultrajones's Avatar
Thank you for confirming. I updated the file and posted the package update to the HomeSeer3 updater. To apply the change, simply shutdown the plug-in, re-install the plug-in, then re-enable the plug-in.
Ultrajones
Old October 12th, 2013, 10:28 AM
jowens14
Guest
Posts: n/a
New version working here.
Jeff
Old October 12th, 2013, 04:52 PM
I reloaded the plugin and now have a log full of the following-
10/12/2013 4:30:34 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '1' Key being added: '1'
10/12/2013 4:30:34 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '0' Key being added: '0'
10/12/2013 4:30:34 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-1' Key being added: '-1'
10/12/2013 4:30:34 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-2' Key being added: '-2'
10/12/2013 4:30:34 PM Warning Exception adding a (single) pair to the collection: Item has already been added. Key in dictionary: '-3' Key being added: '-3'
Barry
Old October 12th, 2013, 05:16 PM
Ultrajones's Avatar
It is a harmless warning. Ignore for now.
HTML code is On
Getting Unable to check event trigger. Error encountered on line 65 of HSPI.HSPI.Devi fwgarnerjr DooCPUMonitor 4 July 30th, 2006 10:12 PM
Dim reports? Near76 Insteon Plug-in (Mark Sandler) 1 January 30th, 2006 09:35 AM
Ski Reports kevind Script & Plug-In Library 1 August 25th, 2005 10:32 AM
