Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Ultra Scripts and Plug-Ins > UltraGCIR HSPI
UltraGCIR HSPI Discussion area for the UltraGCIR HSPI plugin.
Old February 13th, 2014, 04:22 PM
brsanders brsanders is offline
Events trigger on HS startup
Using HS2PRO, UltraGCIR HSPI. Trying to replace Global Cache plugin. Have 3 relays, 5 sensors, and just starting with IR - GC100-12.
The problem is with triggers based on the sensors. An example - use two of them for doorbells. I trigger ( someone pushes the bell and closes the circuit ), based on a "device value change when sensor becomes "inactive -( or 0 ) " ' - announce someone at the door and play chimes. Everything works fine except that at HS startup - when the ethernet connection is established - it triggers the events. I guess it doesn't recognize that the sensor/device was "inactive" at shutdown and believes the value has become newly "0".
Any suggestions ? I run a speaker startup script for all the speaker locations after the events trigger - so it's really not a big issue, just something I'd like to get solved. The Global Cache plugin was set up the same way - except used "status change becomes off" - never had this problem.
Thanks in advance for any solutions
Bruce
Old February 13th, 2014, 06:20 PM
swanie2000 swanie2000 is offline
You described the problem very well. I have the exact same issue, with my DSC alarm plugin. Everytime HS3 restarts, the plugin see all the zones "become closed" and I have an event that sends me a text when the side gate closes. So everytime HS3 restarts, I get a text message that says the side gate just closed.
I do not have a workaround, but subscribed to this thread to see where it goes.
Old March 11th, 2014, 08:23 AM
I guess there's no help
Either we are the only ones to see this problem or no one has a solution. I have not been able to find a workaround. The device "value" is saved when you "disconnect" the GC100 - so no triggering. So this is only upon startup of Homeseer.
Old March 11th, 2014, 09:24 AM
prnorton prnorton is offline
I have that same problem with a door sensor that flashes a light when the door opens. After an HS3 restart the light flashes one time and them it works OK.
}{ Phil }{
Old March 11th, 2014, 10:30 AM
Hey Bruce,
I just noticed you listed your problem with HS2PRO. I never experienced this problem in HS2.
I am currently running HS3PRO, and have this problem only on HS3PRO.
I experience this problem with the DSC Envisalink plugin. Maybe the issues are with the plugin's and not with Homeseer it's self?
Old March 13th, 2014, 09:35 AM
I agree
Given that it has never happened to me before - I tend to agree - it's in the plugin. When I used the Global Cache plugin - no problem. So it doesn't appear to be related to HS2Pro or the hardware itself. Only difference in the plugins is that one used "status" and one uses "value" triggers.
HTML code is On
Oddity with events/multiple events trigger (if they share a name) from a single press BootsC5 HS2 / HSPRO 0 January 26th, 2009 11:53 PM
Valve trigger on HS startup Steve Cougar mcsSprinklers 1 April 30th, 2007 12:34 AM
Trigger HS events based on Media Player events (Song started/ended) epsteing Windows Media Player 15 December 17th, 2002 09:44 AM
