Hi folks, I'm running HS3 on a RPI2- It was working well and with reasonable memory utilization on v177..
I updated it to v182-After that it began to hang once in a while and I began checking available memory. It seems to be going lower than I noticed in the past....Available memory is dropping into the double digits....eventually it will hang or slow down till I restart the HS3.
I loaded BLGarbage and it didn't seem to help (removed now)
I updated to v187, no change
I reinstalled at V177 and then V182 with the full builds and it still has not improved.
I performed an apt-get upgrade and RPI-update...also but that has not made any difference.
Notes...
only Plugins are: Mark Sandler - Insteon, WeatherXML, HSTouch.
My questions are...
Is this memory consumption normal with HS3 on a PI2 B
IS there a script I can run schedule that wil clear it up (outside of killing and restarting HS3)
Looking for any other suggestion to resolve
Any help would be appreciated.
Notes...
My questions are...
