Can you please post the pushover.vb script? Thanks!
Z-Wave Lock Events Script - Discussion Thread
Originally posted by ajgyomber View PostCan you please post the pushover.vb script? Thanks!
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Al,
Thanks for posting the script. It works great and eliminates the need to have HSTouch running on my mobile phone all the time to get notifications. This is an awesome set of scripts.
--AJ
Originally posted by sparkman View PostThe pushover script has been reattached (http://board.homeseer.com/showthread.php?p=1156347).
Cheers
Al
I believe it should work in linux (under Mono), but have never tested it. You may need to update the scripting references in the settings.ini file under the config folder. This is what mine look like, although I had these before I created the script so some are likely not needed for this:
Code:ScriptingReferences=System.Management;System.Management.dll,System.Web;System.web.dll,System.Windows.Forms;System.Windows.Forms.dll,System.Drawing;System.Drawing.dll
Cheers
Originally posted by dlover View PostHmmm. My settings.ini file doesn't have a "ScriptingReferences" section at all. Strange that that would be the case. Maybe it isn't used with Mono? or it is somewhere else?
Cheers
I added that line and all of my scripts started erroring out, referencing the System.web.dll. So, I pulled out the "System.Web;System.web.dll" from the scripting references line. The existing scripts work again, but yours still fails.
Too bad, I was pretty excited to use this, after adding a couple of zwave door locks to my house. If you can think of anything else, let me know.
Originally posted by dlover View PostI added that line and all of my scripts started erroring out, referencing the System.web.dll. So, I pulled out the "System.Web;System.web.dll" from the scripting references line. The existing scripts work again, but yours still fails.
Cheers
Can you try the attached as a test? It does not do anything, but uses a different split method, so want to see if it generates errors in the log. This one will require 4 parameters, rather than 3 as it is based on a new version I was working on that allows specifying the locktype for those with more than one brand of lock. The parameters with it should be:
Code:344,Garage Entry Door,347,Kwikset
AlLast edited by sparkman; November 28, 2015, 01:51 PM.HS 4.2.8.0: 2134 Devices 1252 Events
