Couple of new config questions
    Couple of things to get me started using the Vista plugin fully...
    Firstly, the HS3 Help Page seems to display the wrong text against the Vista Plugin Documentation (the URL link is however correct...)
    and second,
    What event trigger should I be using to make a HS3 event fire on say the alarm being 'Armed', or set to 'Armed Night Stay' ?
    i'll make a note to fix the help text
    there are vista alarm triggers you can use against the System Status or Partition status device to test for various arm states
    Mark
    HS3 Pro 4.2.19.5
      Cannot get any triggers from Ademco 15P
      So it seems that my AD2USB is able to control my 15P alarm panel fine, but cannot see any status at all (e.g. Zones, Partition or System Status = Night Stay, etc.). All status read 'Unknown'. Strangely I can see the keypad display text against the 'Last Panel Message' device fine...
      Without this working, I suspect testing any events on Vista triggers is pushing it a bit!
      Help!
        you will need to configure partition 1 within the plugin. you can reuse the keypad address and user code
        Mark
        HS3 Pro 4.2.19.5
          I did that, but still just see unknown for system and partition status. Here's my plugin settings...
            can you post a hs log snippet of the panel msgs received. filter your log for Vista Alarm messages
            Mark
            HS3 Pro 4.2.19.5
              Sorry Mark. I found my problem. Everything was working fine back in January, and then I used a longer USB cable and relocated the AD2USB box. Low and behold, 1 of my alarm panel side wires was loose!
              A dead giveaway should have been my last successful 'Last Panel Message' - which was 1/27....
              Everything is, how they say, hunky dory now!
                Glad you got it working.
                Mark
                HS3 Pro 4.2.19.5
