I am running HS3 ZEE S2 Edition 3.0.0.318 and ZWave 3.0.1.110
When I try to delete or set the user codes for the Schlage lock Zwave crashes.
It happens when I enter the user code before I even execute the event.
I havent added in the debug to the log yet but can if that might help? Here is the current log.
Apr-21 07:49:47 Z-Wave InitIO called, plug-in version 3.0.1.110 is being initialized... Apr-21 07:49:47 Info Plugin Z-Wave has connected. IP:127.0.0.1:32803 Apr-21 07:49:45 Warning I/O interface Z-Wave is down, executable is not running, restarting ... Apr-21 07:49:35 Info Plugin Z-Wave with instance: has disconnected
