Plugin stopped reading Nest data
    #76
    It's working
    Can you tell me what port or address should I whitelist in the firewall?
    Thanks again for your help
      #77
      We need to unblock 52.200.120.206
        #78
        well, the plugin does not connect to a specific IP but to a Nest url, so I guess if you only unblock 52.200.120.206 and then Nest changes its server IP, it will starts not working again.
          #79
          Do you have the URL? I know this IP come from amazon...
            #80
            the plug-in use the following base urls with different paths and parameters
            https://home.nest.com
            https://api.home.nest.com
            https://developer-api.nest.com
