Great! Thanks.
UltraMon HSPI For HomeSeer 2.2
Originally posted by IKUS View PostJust thought I'd throw in my two cents on the usefulness of this plugin. I have it monitor for the presence of my mobile phone's wifi connections and it uses this information (along with other things such as motion detection and door/window status) to help determine occupancy status.
Example: Assuming that I always keep my mobile phone with me, all doors and windows are monitored by HS, the pets don't open/close doors, and nobody ever leaves through a window... I can have HS assume the house is occuppied if 1) ultramon detects the presense of my mobile phone, 2) motion is detected on the 1 high-mounted (pet-proof) sensor in the house, or 3) an interior door is opened or closed. The house remains occupied until an exterior door is opened and then it has to start making decisions on whether or not everyone left through that door...and again I use ultramon to help make that determination.
Hi! I Like your thoughts (scenarios). How can you make so complex calculations (if then else, double or triple ORs with ANDs etc)?
Is there a proper plugin that makes their programming easy, or is a result of a very deep programming into homeseer?
I'm somehow new to the world of homeseer and i have some good ideas to make with this software, so i would like to know about what to start learning first!
Do i have to learn about scripts?
Or to start learnng a new plug in?
I have already understand all the way homeseer works, but i'm still new.
After i red your scenario, i saw that you are the one that could tell me...
So, If you would like write me 2 sentences of your experience, would be so helpfull for me.
Thank you in Advance, Kostas
Originally posted by coolgas View Post______________________________________________________
Briefly, I have a virtual device called "Occupied" that is set by the events i listed in the previous post. ie...when interior door 1 is opened, set "Occupied" device to ON...or when pet-proof motion sensor detects motion set "Occupied" device to ON...or when phone's wifi comes in range set "Occupied" device to ON. it gets a little trickier for unoccupied, as i can't just rely on non-motion or phone wifi status...what if I'm motionless in bed or vegging out on the couch or if the phone dies? So based on trial and error I've worked out that an exterior door is never opened without everyone leaving the house AND NOT followed up by one of the following things within 10 minutes: open/close an interior door, open/close the refrigerator, pass a pet-proof interior motion detector, turn on/off a media extender, or phone's wifi remains within range. In other words, upon opening of any exterior door, the house assumes that it will be unoccupied in 10 minutes unless proven otherwise. So events on each exterior door trigger a 10 minute delayed setting of the "Occupied" device to OFF and events which would prove that someone is still home trigger a cancel of that delayed event, leaving the "Occupied" device ON. The "Occupied" device itself then becomes a condition for other events and scripts. I'm simplifying it a bit as there are all kinds of conditions on each of my event triggers to account for things like me being in the yard but someone else still being in the house, plus I actually have another level of occupancy on top of this for when I'm out of town but you get the point. It's all do-ble in HS...no scripting needed.
Since yesterday I'm testing this plugin.
Few questions
- How can I reduce the check time to 15 seconds.
- In .net 2.x there is a ping bug. On my configuration HS will crash every few days when the ping command is used inside a plugin.
This was the case with:
PHNetwork and BLLan
I hope the testing is done using another methode.
Originally posted by Chak View PostSince yesterday I'm testing this plugin.
Few questions
PHNetwork and BLLan
I can add an option to reduce the check time to 0, which means it will continually check the monitored hosts without pausing. This shouldn't cause any additional load on the system. It will take a few weeks to post an update as I am currently in the middle of a major revision allowing for device types to be created and change and deleted.
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by Ultrajones View PostYes, I acknowledge there is a .net 2.0 ping bug if done incorrectly. However, the UltraMon HSPI does it correctly. I have been running this code 24 x 7 x 365 without any issues.
Ultrajones
Yes, very soon. I just finished changing the icons from 16x16 to 32x32. The new icons are .png icons renamed to .gif so they scale back to 16x16 if the user wants the smaller icons. I also added the ability to add device types which would require the user to provide their own 32x32 icons. I also converted the install to the newer HomeSeer installer template. I hope to complete testing tomorrow and post the update this weekend.
Guest
Ping Options
Do Attempts, Mark Failed After and Ping Timeout come into play during each Check Interval or elongate the process?
What I'm trying to determine is if Check Interval is set for example to 5 minutes, then depending on the other settings if the amount of elapsed time before UltraMon updates status could actually be multiples of 5 minutes or would be every 5 minutes regardless of the other settings.
Thanks.
Attempts and Ping Time-out will increase the time it takes to complete a round of checks. However, the latest release updates each host as soon as the status is determined instead of waiting until the end of the check interval. "Marked Failed After" does not cause an delays during the check interval.
In summary, you cannot predict when the underlying HomeSeer devices will be updated.
Guest
Is there a logic flowchart? If:
Delay Between Checks = 5 minutes
Attempts = 5 times
Marked Failed After = 3 times
Ping Timeout = 3 seconds
and the device in question is down/not responding, is the check going to be performed again every 5 minutes or every 25 minutes (5 delay minutes between checks x 5 attempts)?
I'm trying to understand in order to set the most reasonable frequency of detection with the least amount of unnecessary network traffic.
Settings not saved
Yesterday I installed this plugin but when I restart the Homeseer service my devices are reverted back to how they where discovered.
I lose the name and the image and all my devices are computers again not a router, iphone etc.
I use Windows 7 x64 ultimate and Homeseer as a Windows service.
Default the Homeseer service is started under the System account, I tried to run the service as a admin user, but this does not work either, my settings or lost after a restart of the Homeseer service.
Is this a known problem?
Frank
