I am trying to setup the BLRF plugin to try to get all of my stuff off of HS2 on to HS3 and I am not having much luck. I have the WGL W800RF32 receiver hooked up to a usb/serial adapter at port 4. I don't know if I should be using MCcommLib or Serial port in the Options page, there isn't anything in the documentation showing this. If I get this setup right, should I see an entry in the log from myHR12A palmpad remote?
Thank you.
Thank you.
