Help with device status monitoring
    I would like an event to trigger if the status of a device is On for a period of 10 minutes straight. The application is my ejector pump, and if it is running for more than 10 minutes straight, then there is something wrong with it. After two such events (one of which was an ecological disaster in my basement!), I am hoping to use HS to warn me.
    Do I have to go to a script, and if so, is there one out there, or can I use Event Conditions through the standard event set up? I have played around with stardard event set up and don't really see this particular application. Thanks.
    You can set up an event that tigger is condition. Then select te device condition "Has been on at least" 10 minutes. That should do it.
      Thanks, Rupp.
