Hello,
I am having an issue getting the Maestro 100T modem working on my system. At one point I had a GSM version of this modem working, then converted over to a CDMA version and now HS SMSGW cannot get connectivity with the unit. I have reliable connectivity using a standard terminal program (PuTTY), so this is not an issue with the modem or driver. I have attached some information that hopefully will be helpful in resolving the issue, thank you in advance for any assistance with this.
Thank you,
Mark
A few addition notes:
1. Yes, I do have the COM port configured for the same come port that PuTTY is able to connect to.
2. I have rebooted the PC a number of time to see if this would help, no lock.
3. I have un-installed and re-installed the drivers multiple times to see if this would have any effect, no luck.
Thank you,
Mark
