wget of RaspberryIO_remote_install_3-0-0-12.zip - invalid file
    Hello:
    When I download the remote client I get a 194k file that is an invalid zip file. I am using Stretch - as an fyi your mono upgrade procedure should get updated - install dirmngr and ignore later security errors but I was able to get through that - now I've got this issue ;(
    Archive: RaspberryIO_remote_install_3-0-0-12.zip
    End-of-central-directory signature not found. Either this file is not
    a zipfile, or it constitutes one disk of a multi-part archive. In the
    latter case the central directory and zipfile comment will be found on
    the last disk(s) of this archive.
    unzip: cannot find zipfile directory in one of RaspberryIO_remote_install_3-0-0-12.zip or
    RaspberryIO_remote_install_3-0-0-12.zip.zip, and cannot find RaspberryIO_remote_install_3-0-0-12.zip.ZIP, period.
    I also tried downloading from a wheezy build, no difference
    I finally downloaded via windows which gives me a 961k file. So I guess this is an FYI - no idea why wget isn't getting the entire file
    weird....
    I just quickly tested using a Ubuntu 17.04 VM, and it worked fine.
